Author Topic: Tm 250 build up  (Read 8582 times)
Re: Tm 250 build up
« Reply #15 on: May 21, 2012, 05:11:03 pm »
wow, love your work. she came up a pearler.
Offline Nipper
Re: Tm 250 build up
« Reply #16 on: May 21, 2012, 06:43:44 pm »
Credit to you oldfart that looks great. Can you give us a close up of the rear chain guide I like the look of that is it a KTM part?
Re: Tm 250 build up
« Reply #17 on: May 22, 2012, 04:33:18 pm »
No she is a in house fabrication  using a teflon runner on the bottom of the arm much the same as a Rm 250 / 400 T. A section has been welded on the botton of the arm @ the first bolt( rear ward )  and  has a 2 fold effect ...... guide to bolt onto which will not clash with sprocket when adjustment is required  plus a bit of bracing.
I have made a template if anyone wants a copy.
« Last Edit: May 22, 2012, 04:46:05 pm by oldfart »
Offline Nipper
Re: Tm 250 build up
« Reply #18 on: May 22, 2012, 04:55:02 pm »
That is a sweet job with the guide, well done. If it is not too much trouble can I get a copy of the guide i would like one on my TM ...doesnt have one at the moment.
Re: Tm 250 build up
« Reply #19 on: May 22, 2012, 05:00:02 pm »
Pm me a  fax # and I will send it off tonight
Offline Nipper
Re: Tm 250 build up
« Reply #20 on: May 22, 2012, 05:04:09 pm »
Have sent pm cheers
Re: Tm 250 build up
« Reply #21 on: May 22, 2012, 05:54:25 pm »
working drawings faxed to F / station  ;)
Offline Dono113
Re: Tm 250 build up
« Reply #22 on: June 05, 2012, 10:59:25 am »
You've done Andy proud !!! ;D ;D
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
Re: Tm 250 build up
« Reply #23 on: June 05, 2012, 11:37:00 am »
I can see the bee's on this honeypot at the Nationals, Oldfart  :P  :P well done to you !!
And Here she is all tarted up .... just need to get a few laps in before the Nats
