Author Topic: Now lets use this board  (Read 54281 times)
« on: July 26, 2007, 07:10:33 pm »
Hello everybody and welcome   :D As is plain to see my constant requests (nagging...) for a VMX Sidecar (*)forum spot have been very kindly met. So please fire your sidecar questions , tips ,info, piccies, reports ,back slaps, and of course whinges and grumbles here!!  Yep here! for all too mull over , cause then suggestions can be made for the improvement of this most exciting, physical and spectacular form of racing. Cheers  Tim754.
(*) Don't mention this to Mister Admin but, Dirt track ,Road trials ( the South Australian type),Short circuit and even the mighty Vintage Speedway monsters can sneak in here....if you like :: ;)
Re: Now lets use this board
« Reply #1 on: July 26, 2007, 07:13:08 pm »
You're mad!
« Reply #2 on: July 26, 2007, 07:35:09 pm »
Nasty Brute Nathan ;D Retract that  and tell everyone how Yamaha engines make great sidecar power plants and I will give you about two thirds of an electric start AT125 (Has no wheels .plastic covers, pipe or seat covering but good metal seat base) Cheers bugger Tim
« Last Edit: July 26, 2007, 07:43:50 pm by Tim754 »
« Reply #3 on: July 26, 2007, 07:56:42 pm »
Who said Mad was a bad thing? ;)
Of course Yamaha engines are excellent for sidecars - they're excellent for everything, including minding the kids, adding flavour to exotic meals, and reducing the effects of Climate Change.
« Reply #4 on: July 26, 2007, 08:04:27 pm »
Crikey that was very very sucky ::) I accept  ;)Pick up the 125 when you can...  ::)  (Sidecars/SL70s hint)
« Last Edit: July 27, 2007, 12:16:05 am by Tim754 »
« Reply #5 on: July 26, 2007, 08:41:05 pm »
Funny, the Boss and I were discussing your madness just before I posted... We agreed that - like most VMX types - you are "good mad". Wasn't trying to suck up at all...  :o
Sure you don't want the DT125 wheels for your AT1?
Er... Sidecars. Weren't we supposed to be talking about sidecars?
« Reply #6 on: July 26, 2007, 10:09:35 pm »
Making an SL70 Sidecar........... of course   ::)
« Reply #7 on: July 26, 2007, 11:07:28 pm »
Cant wait to see the sl sidecar Tim  ;D
Offline brent j
« Reply #8 on: July 26, 2007, 11:23:52 pm »
I once made a side car out of one and a half push bikes. (Does that count?)
Passenger and rider both pedaled, worked a treat til it broke in half. Thank F I was riding that day!
brent
VBMX sidecar imposter
« Reply #9 on: July 27, 2007, 11:29:22 pm »
who was doing who to get this side car lot there own sub board ?
next thing it will be rally car drivers in here  :o
« Reply #10 on: July 28, 2007, 01:19:32 pm »
Hey Tim,
Tell us about your Bathurst exploits on the triple.I'm assuming that was before The Chase.Airbourne over the last hump at 150mph!!! Apparently Peter Campbell is restoring the 'Flying Bedsted'* did you ever see that piece of insanity?
* The Flying Bedsted as it became known was a 'sidecar' in name only was similar to a Morgan(2 wheels at the front) the insane thing about the Bedsted was the swinger sat right at the very front between the wheels,so if you were not holding on when the brakes were applied .........
« Reply #11 on: July 28, 2007, 03:06:15 pm »
Was that the Mini powered thing? I (along with a few others, thanks to another forum member) am in possession of a DVD which includes some circuit sidecar stuff from the late 1960s or early 70s.
There's one that looks like a Mini special but with only one rear wheel - and the crew sit in it, next to each other. The commentary describes it as "controversial"...
« Reply #12 on: July 30, 2007, 01:40:09 pm »
Lozza I will get back later about Bathurst Suffice to say it was before the wossie chase and run offs and kitty litter and all that fairy shit. Nathan they are called Cyclecars. I think Jim Scarsbrooks Australian  Motorcycle Heritage Books should cover those " different " Machines. Cheers
« Reply #13 on: July 30, 2007, 07:48:50 pm »
Yes yes as I thought Tim,pre everything. ;D
I don't think the Bedstead had a mini engine I think it might have had a Vincent 1000,might have had it at one stage.I'll try and dig up the article.Frightening just to look at.
Tim or Walter you got any links to engine companies(besides Zabel) two stroke of course.Preferablytwins 800-1000cc range?
« Reply #14 on: July 30, 2007, 08:15:39 pm »
Lozza the giant two stroke twins were banned from the world title scene some years back.  Much the pity. >:(
