Author Topic: RM125B ignition timing question  (Read 2244 times)
« on: May 17, 2012, 01:41:19 pm »
Hey guy's,
I have just finished rebuilding the engine in an RM125B that I recently bought, I never started it since buying it before rebuilding (although did here it run for 5 seconds before I bought it).
I noticed that the ignition timing was set to full advance when disassembling the engine, upon reassembly I set the stator to the mid position as stated in the workshop manual.
The bike was real prick to get started, lots of spit-back through the intake; started burning my new aircleaner element!!!  It would rev out pretty cleanly but would just die at lower rpm's.
So thinking 'timing' due to the spit-back through the intake, I advanced the timing to full advance .... it started a lot easier and would nearly run well at low rpm.
So I broke out the rat-tail file and thought I'd elongate the stator adjustment slot; with even more advance it seemed to run even better!
Any idea's from the Guru's here?
Re: RM125B ignition timing question
« Reply #1 on: May 17, 2012, 02:08:04 pm »
It's possibly a stator or flywheel from something else..
« Reply #2 on: May 17, 2012, 02:26:17 pm »
Hmmm good call, might try even more advance
« Reply #3 on: May 17, 2012, 03:05:18 pm »
Buy a timing light, make some reference marks....................and use them.
« Reply #4 on: May 17, 2012, 03:16:52 pm »
Yep, on to it, thanks
« Reply #5 on: May 21, 2012, 02:19:49 pm »
Would anyone know what ignition advance I need for the 125B in mm?  I'm guessing from all I'm reading that about 2.00mm is in the ballpark but I'd prefer to know from somebody that's been there.
