Author Topic: RT2MX DT2MX MX250/360 Rear Sprocket  (Read 2626 times)
Offline Big Al
« on: May 16, 2012, 10:34:30 am »
Hi Guys!
Does anyone know who does after market rear sprockets 50 or 51 teeth to suit RT2MX DT2MX MX250/360A?
Alloy or steel doesn't matter.
OEM is a #322(RT2MX) part number and is different to DT1, MXB, YZA etc.
Re: RT2MX DT2MX MX250/360 Rear Sprocket
« Reply #1 on: May 16, 2012, 10:39:25 am »
I got mine from John Titman. Fairly expensive, but not outrageous.
Offline Big Al
« Reply #2 on: May 16, 2012, 11:06:30 am »
Thanks. I'll give Titman a call.
« Reply #3 on: May 16, 2012, 12:34:03 pm »
is that the one with the 80 mm somthing centre ? if you luck out i might have some in 52
Offline Big Al
« Reply #4 on: May 16, 2012, 02:21:06 pm »
Hi Freakshow,
It has a 90mm centre hole and bolt holes are 110mm PCD
« Reply #5 on: May 16, 2012, 09:33:40 pm »
got mine from John as well . send the original up to him though .
