Author Topic: RM 400 Rear brake plate - PE equivalent?  (Read 2249 times)
Offline Bruno1969
« on: May 08, 2012, 06:59:55 pm »
Hi all,
Over the weekend, and during the first ride of my freshly rebuilt 78 RM 400 I somehow managed to brake the rear brake plate.
Got back to the pits and saw that the torque arm had pulled a big piece of the casting off, some where along the line the brake actuating arm also got broken and the cable nicely wrapped around the axle. How the hell this happened I dont have a cooking clue - could it have been if the cable got caught on a knobbly which caused the brake to immediately be applied? But surely I would have felt that?
Whatever - its a mess. Now as i see it I can have the plate welded back togther (I see its magnesium) or I could maybe use a plate from a PE? Here in Saffer land either the welding or the PE plate would be option as RM 400's are pretty scare..
So what say you gurus ? What PE plate would fit? If any....
monaro308
Re: RM 400 Rear brake plate - PE equivalent?
« Reply #1 on: May 08, 2012, 10:58:35 pm »
The only other rear plate that matches going by my Suzuki parts reference is the 1978 RM250C2.
I'm sure something could be matched up from another RM/PE of the same hub diameter.
It doesn't answer your question though ;D
Offline frostype400
« Last Edit: May 08, 2012, 11:05:05 pm by frostype400 »
1971 tm400 and PE's
clutchslip
« Reply #3 on: May 10, 2012, 04:54:28 am »
I think there has been a bit of discussion previously re the problems with 30+ year old magnesium castings....particularly hubs
