Author Topic: Yz125c/x carbs  (Read 2569 times)
Yz125c/x carbs
« on: May 07, 2012, 12:05:56 pm »
I'm running a 30mm carb on my 125c with an X  barrell. I was going to try a 32mm, I think the 34mm would be too much, do you reckon the D jetting specs would be a good starting point?
Re: Yz125c/x carbs
« Reply #1 on: May 07, 2012, 03:03:30 pm »
Yes.
FWIW, My X runs a ported C barrel and the X's 34mm carb. It never feels over carbureted - midrange is much stronger than a stock C.
Don't forget the differences in the airbox to carb boot (C vs X). I think you'll need an X one for the 32m carb.
Re: Yz125c/x carbs
« Reply #2 on: May 07, 2012, 03:25:29 pm »
So you reckon use the 34mm?
Re: Yz125c/x carbs
« Reply #3 on: May 07, 2012, 04:00:10 pm »
If you can find one use a 34 Bing the VA VB Montesa 125 come with these standard, Yamaha's with reed valve can easy take 34
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Yz125c/x carbs
« Reply #4 on: May 07, 2012, 05:21:31 pm »
and if you really want your carby to match your hairdooo....
i have a 1G8 34mm sitting here at my place.
my 125C/X thang runs a 32mm jetted pretty close to "D" specs and i love it!
mine also has the "X" barrel.
« Last Edit: May 07, 2012, 05:52:28 pm by vandy010 »
"flat bickie"
Re: Yz125c/x carbs
« Reply #5 on: May 07, 2012, 06:11:15 pm »
soounds like a deal, I'll bring the carton of teds, you bring the carb ;D
Offline Ted
Re: Yz125c/x carbs
« Reply #6 on: May 07, 2012, 06:20:22 pm »
Have you seen the price of fuel lately? That whopping 34 is sure gonna suck some gas. You must be rolling in it!!!!!!!!!!!!
81 YZ 465 H   77 RM 125 B
Re: Yz125c/x carbs
« Reply #7 on: May 07, 2012, 06:26:02 pm »
you figured out why your wrist is sore yet?
Offline Ted
Re: Yz125c/x carbs
« Reply #8 on: May 07, 2012, 06:41:22 pm »
I`ll bet that 34 towers over your pet dinosaur...glove boy
Offline steveo247
Re: Yz125c/x carbs
« Reply #9 on: May 07, 2012, 10:31:35 pm »
If he doesnt want it i am in need of that carby  ;D
