Author Topic: Shocker bushes need to be 12mm not the normal 10 in them  (Read 849 times)
« on: May 07, 2012, 11:35:33 am »
Need 2 or more shocker bushes for a CR 125 or 250 shocker top mount.
From best i can tell with the measuring stick is they have an Eye diameter of 21.30mm ID ( not sure what that makes the bush ID but must be close to same ) being about 16.20mm wide -  with the original bush eye itself being about 18-19mm wide but assume i can cut it if too wide.
