Author Topic: 81 RM125x No Power at Full Throttle  (Read 3933 times)
Offline PCMAX
« on: April 25, 2012, 07:45:55 pm »
My '81 RM started playing up last weekend it runs great into the start of the power band but then as you hit peak power its like it is running out of fuel or spark particularly if I jam it full open.
I have done the following but the problem persists:
*Replaced the spark plug
*Replaced the plug cap
*Replaced the stator coil assembly
*Cleaned the carby & jets & needle valve & set the float level
*Tried a bigger (270) and smaller (250)main jet
*Pulled the barrel off and checked the piston, rings & reeds
Has anyone had any similar problems or does anyone have any suggestions???
Offline holeshot buddy
  • sunshine coast qld
Re: 81 RM125x No Power at Full Throttle
« Reply #1 on: April 25, 2012, 07:52:48 pm »
is it flat power nothing there
or loading up
check fuel flow from tank i drill out the suzuki one
to a bigger size ;)
follow me to first turn
RMJJ
« Reply #2 on: April 25, 2012, 09:55:38 pm »
Is it the instant you jam the throttle wide open or after a few seconds
Offline PCMAX
« Reply #3 on: April 28, 2012, 08:50:46 am »
Holeshot, don't think its loading up it just dies as im hitting peak power. Its perfect down low and into the first half of the power band.
RMJJ, its the instant I hit peak power (throttle full open) it just dies.
I have also posted this on the Tech Talk thread and after some suggestions there will change the ignition coil and check the exhaust for blockage/restrictions today.
« Reply #4 on: April 28, 2012, 09:51:34 am »
Sounds like fueling to me.
Offline Big John
« Reply #5 on: April 28, 2012, 11:32:32 am »
I had a this same problem with a YZ250 turned, out to be the muffler, it had broken the perforated steel insert and was obstructing full flow of exhaust gas.
Offline bazza
« Reply #6 on: April 28, 2012, 12:25:58 pm »
 Its a suzuki
No seriously,have you owned the bike for a while and this has just happened? Do they have a fuel filter built in to the tap?
Embrace patina
Offline PCMAX
« Reply #7 on: April 28, 2012, 06:02:19 pm »
Bazza, I get good flow from the fuel tap & I have an inline fuel fiter but this has been changed.
I checked the ignition coil today and found that I have 50,000 ohms resistance from the coil (black/white wire) to the plug cap. The book says I should have 10,000--11,000 ohms so I guess ths could be the problem. Unfortunately I don't have a similar coil to troubleshoot with, all the spare ones i have only have one wire and a plug lead.
Does anyone know what the other wire (white/blue) that runs from the ign coil does??
« Reply #8 on: April 28, 2012, 08:51:23 pm »
You can test how much air gap the spark can jump will determine the health of the ignition. A pit bike coil will work fine.
Offline bazza
« Reply #9 on: May 21, 2012, 03:33:51 pm »
Any progress finding problem?
Embrace patina
