Author Topic: EML swing arm  (Read 3234 times)
Offline QLD779
EML swing arm
« on: April 25, 2012, 02:58:35 pm »
Who knows where I can get front swing arm bushes for my EML? They are rubber cushoned steel bushes. Do bearing suppliers stock such items or do I get bronze ones made?
You don't have to be, but it helps.
Offline popeye
  • 1-2-3 wheel's l don't care...All good fun.
Re: EML swing arm
« Reply #1 on: April 25, 2012, 03:16:24 pm »
Try Walter, he is the agent for EML, maybe good suspension shops, or Hi Spec Engineering at Yatla.
IN IT FOR THE FUN OF IT. LIKE MR NIKE SAYS JUST DO IT.
Re: EML swing arm
« Reply #2 on: April 25, 2012, 04:47:27 pm »
Or you could try any automotive shock outlet ....ie Pedders  http://www.pedders.com.au/storeFinder/3
Offline lama
Re: EML swing arm
« Reply #3 on: April 25, 2012, 06:27:20 pm »
talk to wayne mate
Offline EML
Re: EML swing arm
« Reply #4 on: April 30, 2012, 05:26:11 pm »
Just did the Wasp ones, thanks to lama and his dad who got the out of Colditz-oops I mean Rhind Tutt. The front end is like new again-no more excuses for being a wobbler any longer Lama. :D :D :D
They are just white metal/bronze bushes.
Offline QLD779
Re: EML swing arm
« Reply #5 on: April 30, 2012, 07:16:06 pm »
Thanks for the advise guys. Tried to get some to fit up here but nothing. Found an elderly man to turn some up from a chunk of phosfer bronze. Should do the trick with some new titanium bolts. ;)
Offline 270YAM
Re: EML swing arm
« Reply #6 on: April 30, 2012, 07:50:16 pm »
Don't forge to make a steel sleeve to go over the bolt so the bush doesn't bear on the bolt, this will allow you to do the bolts up tight without the bush binding on the ends  ;)
