Author Topic: DG Silencer  (Read 5000 times)
Offline Viper79
DG Silencer
« on: March 27, 2008, 08:52:13 pm »
Hi  Can any one tell me the inside core diameter of a DG alloy silencer for a RM 400T.
Regards
Viper79
« Last Edit: March 28, 2008, 07:53:02 pm by viper79 »
QA50 KO, XR75 K5 Race bike from VMBA days, XR400R1, CRF450R3, RM400T, DR650SE with off road adventure mods, MX360A, YZ400D, YZ465H, IT250H, 1985 Jawa 897 Slider, 2016 Jawa/GM Slider
Re: DG Silencer
« Reply #1 on: March 28, 2008, 07:28:22 pm »
this is quite simple. if your looking for a DG silencer that is a specific fit for your RM then the ID of silencer should be the same as the OD of your pipe. so for example if your pipe od is 28 mm well the DG silencer shoule be 28mm. well actually about 29mm as its gotta have a little bit of clearance to fit on easily, you dont want it to be a hammer on press fit!
so quite easy. go measure your RM 400 pipe and that will give you an idea what the DG silencer ID for you bike should be.
Offline Viper79
Re: DG Silencer
« Reply #2 on: March 28, 2008, 08:02:36 pm »
Thanks LWC,  but its the core size I'm after, most of them are stepped up a size to slip over the pipe.  I have a universal DG one but I feel it may be a bit small in the core.
It's about 1mm smaller than the pipe ID and about 3mm smaller than my YZ465 one.
Regards
Viper79
« Last Edit: March 28, 2008, 08:06:06 pm by viper79 »
Re: DG Silencer
« Reply #3 on: March 28, 2008, 08:20:51 pm »
ive got one of those DG ones comming next week so i will see what mine is. i think its the inch and 1/8 size. i think you would want inch and 1/4 for a open class bike.
Offline Viper79
Re: DG Silencer
« Reply #4 on: March 28, 2008, 08:30:26 pm »
I have bitten the bullet and ordered a 1 1/4 one today hoping its bigger internally.
Fingers crossed!
Viper79
Offline zorroz
Re: DG Silencer
« Reply #5 on: March 28, 2008, 11:19:40 pm »
I have a DG muffler on my RM400 and the core id is 29mm.
Offline Viper79
Re: DG Silencer
« Reply #6 on: March 29, 2008, 09:57:53 am »
Thanks Zorroz,  the one I have measures 25mm, as I thought a bit to small.
Regards
Viper79
