Author Topic: TS90/100 transmission  (Read 1592 times)
Offline brent j
« on: April 21, 2012, 06:26:46 pm »
I need a transmission for a TS90/100. I need the clutch shaft and all gears, output shaft and all gears, kick start mechanism and shifter mechanism.
Basically everything that lives inside the cases
I seem to have everything else, clutch, primary drive, crank, cases. I would consider a complete bottom end
I'll be in North Qld for a few weeks, Brissy for the Nats and at Bulahdelah the following weekend so may be able to pick up.
Brent
Offline the farm
Re: TS90/100 transmission
« Reply #1 on: August 06, 2012, 02:45:38 pm »
yes i have a tf100, plus ts 100 bottom end. some other bits you can have if want.
