Author Topic: Yamaha SC500 big end bearing failure ?  (Read 3684 times)
Offline YZB 500
« on: April 19, 2012, 09:06:11 pm »
Hi All,
Has any one out there experienced big end bearing failures in Yamaha SC500s. I have an SC500 in a YZ360 frame running at the pointy end of A grade.
Easter weekend I had a failure, the rod bearing and crank pin were only 6 meetings old.
It was a 32 degree plus day but I failed in the second race of the day. ( AM ) I was running silkolene at 25 to 1 on 98ron, 440 MJ jet. the appears to be jetted correctly.
No signs of heat seizure on the piston. I have since modified the oil gallery in the rod and changed back to R30.
If any one has experienced a similar fault and has some sound advice please post it.
Regards Gibbsy
Old school is cool !
Re: Yamaha SC500 big end bearing failure ?
« Reply #1 on: April 20, 2012, 01:14:50 am »
Sounds weird the main bearing went, if it was lean etc i say it would happen up the top first.
Maybe the crank wasnt put  back correctly if it was only 6 rides old.  Maybe the crank was pressed too tight and its been rubbing away till it let loose ?  picture would help
was it a genuine yamaha koyo bearing or from a bearing shop ?
« Reply #2 on: April 20, 2012, 08:06:17 am »
not good news Gibbsy - hopefully not too much on the gas when it happened??
Offline YZB 500
« Reply #3 on: April 20, 2012, 03:04:35 pm »
Hi gents,
more info, mains did not fail. its the big end bearing.
Crank was correctly set up to O.M.E. spec.
Rossco i siezed it at Narrogin second to last corner, off the throttle.
I have modified the rod, opening up the oil lube gallery round hole, brought a cut off die grinder, using a 2" disc cut down to 1.1/4" for a smaller radius. i cut a slot similiar to more modern rods, radius all the edges.
If it works i should not have another bearing failure, if it dosen't then you will see a posting for wanting SC500 engine cases.
Cheers Gibbsy
Offline Tossa
« Reply #4 on: April 24, 2012, 08:22:53 pm »
Point one:  only a kiwi would put this in the Foto Forum section!!!
Point two: loose nut on the throttle!!!
Point three:  still a vacancy in team Tossa for you Paul!!haha
Barry
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline YZB 500
« Reply #5 on: April 25, 2012, 12:40:21 am »
Hi ya Tossa,
What do you mean loose nut on the throttle, i have no problem staying on the throttle its the bike i have trouble stay on!
Hence the BSA 50MX Knobbly dents in freds old tank.
Oh would you like me to shear barbara with my next time out, as i have always said, We Kiwi's dont shear our sheep, go find your own!
Regards Gibbsy
Offline Tossa
« Reply #6 on: April 25, 2012, 09:09:19 am »
I'd like it noted i made no sheep jokes!!lol
