Author Topic: RM125B big end, where from?  (Read 1935 times)
« on: April 18, 2012, 07:56:46 pm »
If I need a rod, bearing & crank pin for a RM125B, where would I source them from?  Is the N/T model the same?
Re: RM125B big end, where from?
« Reply #1 on: April 18, 2012, 08:08:35 pm »
http://ozvmx.com/community/index.php?topic=23608.msg231339#msg231339
If you are comparing N / T Rm 125 motors  yes they are different in clutch cover ( screw pattern ) most noticable .....  Crank cases also  ;) will not interchange.
« Last Edit: April 18, 2012, 08:10:14 pm by VMX247 »
« Reply #2 on: April 18, 2012, 11:35:54 pm »
Failing that there would be 100's of 100mm rods to use and a crank pin ground down to 19mm.
