Author Topic: Montesa barrel nuts wanted.  (Read 7407 times)
Offline Nitram
« on: March 26, 2008, 09:09:49 am »
Does anyone know where I can get four of the allen headed nuts that are used to hold the cylinders down on Cappras ?  I know "allen headed nut" sunds like a wierd idea, but trust me, they do exist !  And anyone who has taken the cylinder off a Cappra ( and maybe all kinds of other Montys)  will know what I mean.
I don't need new nuts- second hand is fine, as long as they are in reasonable nick.
Any help or pointers would be greatly appreciated.
Nitram
Offline paul
Re: Montesa barrel nuts wanted.
« Reply #1 on: March 26, 2008, 10:01:47 am »
try ross nimmo at rare monty spares ballarat
gator
« Reply #2 on: March 26, 2008, 10:34:34 am »
What's Ross doing in Ararat ???
« Reply #3 on: March 26, 2008, 02:08:44 pm »
if you need monty nuts, Ross is one  ;D
gator
« Reply #4 on: March 26, 2008, 02:59:08 pm »
Yes hoony Ross is the man for NUT'S ::) :-\
Offline paul
« Reply #5 on: March 26, 2008, 04:00:57 pm »
DONT WORRY ROSS YOUR A LIKEABLE NUT
All Things 414
« Reply #6 on: March 26, 2008, 06:20:57 pm »
Grrrrrrrr >:(. No I'm not!
Nitram, they're pretty hard to get hold of but try Jared at [email protected] and he may be able to point you in the right direction.... :)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #7 on: March 26, 2008, 06:51:57 pm »
I have pretty much exhausted my supply of these cylinder nuts.  Removed them from all my
core motors and new ones from Spain cost over $19ea.! (USD)  I wish I could find someone to
make them.  Anyone want to step up to the plate?
Offline paul
« Reply #8 on: March 26, 2008, 07:00:30 pm »
what do they look like (pic)
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #9 on: March 26, 2008, 07:46:10 pm »
     Specs: 7mm allen at top, rest is threaded. length is 24mm.
  Allen nut area is about 4.5mm deep.
Looks like the allen nut area is separate piece that is pressed down on to the threaded nut.
I can just see a parting line on the outside.
These particular allen nuts were used on just about every Montesa motor from 1967 to 1991!
« Last Edit: March 26, 2008, 07:55:03 pm by cappra »
Offline paul
« Reply #10 on: March 26, 2008, 07:49:48 pm »
hey ross  have you got one that stuffed you could send me
All Things 414
« Reply #11 on: March 26, 2008, 07:52:32 pm »
Okay Paul. PM me your address so as I can divert my hate-mail your way as well.......
Offline paul
« Reply #12 on: March 26, 2008, 07:55:21 pm »
that s not very nice , i get enough of my own   :P
All Things 414
« Reply #13 on: March 26, 2008, 08:03:34 pm »
Probably from my mother. I get a lot from her as well :(
montynut
« Reply #14 on: June 04, 2008, 10:06:26 pm »
I needed some for a bike I was restoring. A 'machinest' friend of mine turned some up in a couple of hours.
He used high tensile bolts parted the head off, drilled the centre completely through ready to tap the thread. Parted off the correct length. Drilled one end the depth of the allen socket section at the same diameter as the 7mm Allen key across the flat. He then installed a section of a 7mm Allen key with a slightly sharpened end in the dead centre chuck. The new 'nut' was held in the lathe chuck and heated to dull red and the Allen key was forced into the new nut this formed the Allen Key socket. The Nut was then tapped from the other end, then turned off to the correct OD.
Sounds complex but was very successful and did not really take long.
