Author Topic: CR 500 ITC shocks  (Read 3882 times)
Offline HL400
CR 500 ITC shocks
« on: April 04, 2012, 05:33:44 pm »
Hi all,  what type of oil goes in a 1983 CR 500 ITC shocks.   HL
Offline HL400
Re: CR 500 ITC shocks
« Reply #1 on: April 04, 2012, 07:37:12 pm »
Thanks for that wasp,  but I'am trying give the rear shocks a bit more dampening I thought if I went to a thicker oil I will get more dampening ?
HL
« Reply #2 on: April 04, 2012, 07:55:39 pm »
Thicker oil will heat up and fade faster than thin oil, you'd be better off revalving to change dampening. Do you want more compression and rebound dampening?
Offline HL400
« Reply #3 on: April 04, 2012, 08:12:26 pm »
Thanks JohnnyO, I'am after more rebound Dampening but not to sure where to start.   HL
« Reply #4 on: April 04, 2012, 08:55:22 pm »
The rebound stack needs to be changed either by going to some thicker shims and/or more shims
Offline HL400
« Reply #5 on: April 05, 2012, 05:46:40 pm »
Sounds good but where do I get the shims from ???   HL
« Reply #6 on: April 05, 2012, 05:53:42 pm »
Steve Cramer products.. the Ohlins importer
Offline NSR
  • Sunshine Coast
« Reply #7 on: April 05, 2012, 07:29:41 pm »
I have ohlins shims and a specs for the ITC shock.  It is a CR not a WR?
Have the shocks been apart?  Maybe the shims on the piston have been put in wrong.
Noel
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
