Author Topic: FOX airshox endbearings  (Read 1999 times)
Offline ola_martin
« on: March 29, 2012, 08:04:26 pm »
What kind of endbearings do you use in these shocks? I was suprised to find a regular sliding bearing instead of an sferical? ball like in an Ohlins.
If the shocks are mounted a bit angled, won't this cause bending on the shaft?
What do you use?
Re: FOX airshox endbearings
« Reply #1 on: March 29, 2012, 09:00:49 pm »
I've always used the standard split bushes, if the shocks are a bit angled like on a Husky you might have to fit spherical bearings. I very much doubt you bend a Fox airshock...
Offline ola_martin
« Reply #2 on: March 29, 2012, 09:28:36 pm »
Thanks.
Didn't meen I'd bend the shaft, but cause bending forces in the shock.
Don't think I'll be able to fit spherical bearings unless I machine out the hole quite a lot, the Ohlins are 22mm outside, Fox is 15.
But I've seen the foxes on just about every bike, and if no one have issues on this I guess it's ok?
« Reply #3 on: March 29, 2012, 09:33:51 pm »
Are they going on a Husky? I guess the best way to tell is bolt them on, put the bike on a stand, let most of the gas out and move the swingarm through it's stroke and see what happens.
Offline ola_martin
« Reply #4 on: March 29, 2012, 10:23:44 pm »
Cheney, but they are angled...
