Author Topic: longtrack frame for freaky  (Read 2000 times)
Re: longtrack frame for freaky
« Reply #1 on: March 22, 2012, 01:34:55 pm »
Yeah have already emailled this guy to see what the plates where for and if a Jawa will fit in there.  still wating on a reply. but could be promising.
« Reply #2 on: March 22, 2012, 03:04:21 pm »
kerry
as far as i know they are all the same jap jawa weslake godden gm ect
jim
Curly3
« Reply #3 on: March 22, 2012, 03:26:55 pm »
Jap engine plates are different to Jawa but I think the rest are the same as Jawa.
Given it's a centre port frame I'd say you'd fit a Jawa or similar in it, might have fun fitting the carb to a 2 Valve Jawa though.
Go for it Freaky, raid that piggy bank again.
« Reply #4 on: March 26, 2012, 08:25:34 pm »
So you dont think a 2 vavle would fit in there ?
Offline Rosco86
  • Brisbane
« Reply #5 on: March 26, 2012, 08:54:32 pm »
It looks similar to the 77 golden frame I have. Have tried a 2 valve in mine and the carbie hits the right hand frame loop. Would need to get inventive with the short intake manifold. If you buy it freaky and it doesn't workout I take it from you for whatever it owes you.
Rosco86
Curly3
« Reply #6 on: March 26, 2012, 09:09:47 pm »
As Roscoe said, with a bit of a cut'nshut anything is possible.
« Reply #7 on: March 26, 2012, 10:06:12 pm »
all you have to do is make a new inlet manifold my tt500 is monted in a centerport staracer and the inlet port is made so the carby is moved back into the centre.i also have a long track roller which should have a weslake in it almost the same but mine is a gen longtracker with speedway front end and stering angle.
« Reply #8 on: March 26, 2012, 10:09:03 pm »
did you check this one out it is made for side port
http://ozvmx.com/community/index.php?topic=23269.0
Curly3
« Reply #9 on: March 26, 2012, 10:12:30 pm »
They're as rare as rocking horse poop, especially over here.
