Author Topic: Replacement ignition for 80 -81 PE 250  (Read 3185 times)
Offline HVA61
« on: February 21, 2012, 09:04:22 am »
Any suggestions for a complete replacement ignition for a 80-81 PE 250.
i note that power dynano list a PE ignition but we are unable to assertain which model this ia applicable to. We have sent numerous emails but have yet to receive a response.
Is there a repair agent etc.
Offline huskibul
Re: Replacement ignition for 80 -81 PE 250
« Reply #1 on: February 21, 2012, 10:26:43 am »
    Have'nt dealt with them but   "RMSTATORS.com"  might be worth checkin out  ?  :)
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #2 on: February 21, 2012, 01:07:54 pm »
Small Coil Rewinds 50 Edols Street North Geelong Australia. (03) 5278 8454
been at it since Adam was a boy just ask for Bert
Offline frostype400
« Reply #3 on: February 21, 2012, 09:43:38 pm »
The power dynamo ignition is for the 1980 onwards models look at the photos carefully, you can clearly see its fitted to a 250 Z on the website photos.
But it should work on 77-79 aswell but just check on flywheel outer diameter first to make sure it will fit iniside the 77-79 stator cover
Also one guy uses one on his PE400 fine.
« Last Edit: February 22, 2012, 10:07:06 pm by frostype400 »
1971 tm400 and PE's
Offline HVA61
« Reply #4 on: February 22, 2012, 08:21:40 pm »
Thanks for the advise , we ordered the power dynamo unit today.
