Author Topic: 93 CR500 Cases  (Read 9752 times)
Offline utsman
93 CR500 Cases
« on: March 20, 2008, 09:13:33 pm »
I have pulled the motor from the beast for a rebuild.After taking the cylinder off I have found some small cracks in both case halves just around the little holes below where the transfer ports would be(main bearing lube holes??) How drastic is this? Anyone seen it before?
UTSMAN
Offline holeshot buddy
  • sunshine coast qld
Re: 93 CR500 Cases
« Reply #1 on: March 20, 2008, 11:02:53 pm »
just check and make sure they are not casting marks
very unusual to crack there ;D
follow me to first turn
Re: 93 CR500 Cases
« Reply #2 on: March 21, 2008, 07:36:51 am »
holeshot is right about his Honda knowledge for once, sometimes casting marks do look like cracks
Offline utsman
Re: 93 CR500 Cases
« Reply #3 on: March 23, 2008, 10:44:56 am »
Well I am pretty sure they are cracks as my fingernail catches on them. Might have to get an opinion from a bike shop. Hope I am not up for new cases >:(
Re: 93 CR500 Cases
« Reply #4 on: March 23, 2008, 10:56:14 am »
post up some detailed photo's if you want. i have a CR500 pressure plate spare that looks like it is cracked but it is casting marks too. i will post it later to compare if you want
Offline utsman
Re: 93 CR500 Cases
« Reply #5 on: March 25, 2008, 06:44:24 pm »
Having trouble with pics. I will try 1 at a time
Offline utsman
Re: 93 CR500 Cases
« Reply #6 on: March 25, 2008, 06:45:17 pm »
Here another
Offline utsman
Re: 93 CR500 Cases
« Reply #7 on: March 25, 2008, 06:46:38 pm »
Why me >:(
What you think guys. Please tell me about the casting marks again
STU
Re: 93 CR500 Cases
« Reply #8 on: March 25, 2008, 07:08:50 pm »
utsman what part of the crankcase is that? can you do a shot from a bit back to show the whole case?
is it in a stressed area?
Offline utsman
Re: 93 CR500 Cases
« Reply #9 on: March 25, 2008, 07:31:53 pm »
Hey Hooney,
These are the holes that sit just below the transfer ports. I presume they are to lube the main bearinggs. You can see the crank half in the right of the first picture. I would'nt think they are particularly stressed. I will go for another photo.
Offline utsman
Re: 93 CR500 Cases
« Reply #10 on: March 25, 2008, 07:42:56 pm »
Here Ya Go Hoony
See the holes on each side of the engine. This is bad aint it?
STU
Re: 93 CR500 Cases
« Reply #11 on: March 25, 2008, 09:07:41 pm »
Stu, i reckon you will be right as they look like casting marks to me.
i will bow to others if they think different. i assume you have not split the cases to look further.
Offline utsman
Re: 93 CR500 Cases
« Reply #12 on: March 25, 2008, 09:36:11 pm »
Not yet. Let you know how I go.
Thanks Hoony
Re: 93 CR500 Cases
« Reply #13 on: March 25, 2008, 10:42:31 pm »
casting marks ;D
Offline utsman
Re: 93 CR500 Cases
« Reply #14 on: March 26, 2008, 06:09:17 am »
I'll take your word for it guys.
Cheers :D
