Author Topic: Crank Seal Problems  (Read 2753 times)
Offline Stewart Allen
Crank Seal Problems
« on: February 15, 2012, 08:11:54 pm »
Ok, need some advise, installing a new crank seal, the outer rim of the seal is rubberized. There is a groove in the bore where the seal is to be fitted, looks like damage from levering old seal out, groove is about .5 - .75 mm deep.
Question is do I fit seal with some kind of sealant around the outside to fill in the groove, if so what do you recommend, or do I install it and hope the rubberized outer rim will take up the groove.
Any advise/opinions greatly appreciated.
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
Offline PEZBerq
  • Brisbane
Re: Crank Seal Problems
« Reply #1 on: February 15, 2012, 09:17:54 pm »
Best to do a leak test after you build the motor to check the seals and everything else is tight. Pressurize to 6 psi or so and see if it holds pressure for several minutes. You will need to make up plugs and seals for the
exhaust and intake so you can pressurize and monitor the pressure. Well worth it - good practice for any engine rebuild. Peace of mind.
I don't see what harm using some sealant will do to the crank seal. Another option is Belzona or liquid metal to fill the groove and then machine or sand back to smooth. If its under the seal it should be fine. Good luck.
Offline pmc57
« Reply #2 on: February 16, 2012, 10:14:36 pm »
Use one of the "remain soft" type sealants like LOCTITE Master Gasket 518 around the outer rim of the seal. It will help fill any gaps along with the rubberized outer rim.
« Reply #3 on: February 17, 2012, 08:10:19 am »
Thanks guys
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
Offline Dan-166
« Reply #4 on: February 17, 2012, 10:46:00 am »
Hey Stew,
You going to make it back onto the track this year? Hope all is going well on the health front.Cheers
Dan
« Reply #5 on: February 17, 2012, 10:58:48 am »
Hi Dan,
          Hoping to get to Glenbawn and continue on from physical & financial health allowing.
Stewart
CHEERS STEWART
# 74 Heaven
CR125M
SL175 bitza
IT250D needs work
YZ125F
Offline Dan-166
« Reply #6 on: February 17, 2012, 04:00:02 pm »
That's good Stew, hope to see you there.
