Author Topic: BSA B-40 cam  (Read 1893 times)
Offline huskibul
BSA B-40 cam
« on: February 14, 2012, 02:54:08 pm »
    Looking for a BSA B-40  (65' up)  cam in good usable condition ! will also consider B-44 (pre 70') with flat follower's -also kickstart parts inc ratchet/pinion gear/bush/ springs etc-send PM please
Offline bazza
Re: BSA B-40 cam
« Reply #1 on: February 14, 2012, 03:07:20 pm »
will a b50 cam work ? Have one in my B44 goes well.
Kick start  bits turn up on Evil bay and do ware out then jam
Embrace patina
Offline huskibul
Re: BSA B-40 cam
« Reply #2 on: February 14, 2012, 06:35:48 pm »
    Yeah baz aparently you can fit them if you change the inner cam bush -b50 and later b44 use a bigger diameter inner journal ,b50 timing gear is thinner so you have to thrust it as well ,as you said they come up on US ebay a bit but just putting the feelers out locally first, i have a couple of std b40 ones, one is rusted the other has some pitting on one lobe not sure about using it-cheers
« Last Edit: February 14, 2012, 06:39:35 pm by Huskibul »
