Author Topic: ID this head please.  (Read 12435 times)
Offline YZ250H
  • Back in QLD Baby !
Re: ID this head please.
« Reply #15 on: February 19, 2012, 05:56:21 pm »
Ok - I've got a photo of that head from the front. See if this helps.  I found some pictures of Wayne's C on here.  The shape looks to be the same.  Wonder where the second plug came from  :-\
I have another one that came with the bike.  What is that from ??
« Reply #16 on: February 20, 2012, 07:19:34 pm »
Sorry YZ250H its not a yzc 250 head the C did not have any cut aways on any of the fins . the fins are to large the C ones are about 1'' max long on the ctr fin   Ill post photo over the next couple of days . the single plug head looks like a YZ 250 D 1977 .
Iain
« Last Edit: February 20, 2012, 07:22:18 pm by iainyz »
« Reply #17 on: February 20, 2012, 07:49:24 pm »
Tentpeg, sounds like this bike of yours was some sort of factory prototype/rolling testbed. You should see how much Yamaha will buy it back for.
« Last Edit: February 20, 2012, 09:45:41 pm by mainline »
Offline Ted
« Reply #18 on: February 20, 2012, 08:58:52 pm »
Yammy won't be interested. I think it was made in North Korea or Honduras or somewhere using the early jap psyche of copy and improve, unfortunately lack of funds ruined the project
Buy a canoe
81 YZ 465 H   77 RM 125 B
Offline YZ250H
« Reply #19 on: February 21, 2012, 07:02:40 am »
Iain
Yeah, thanks Iain.
I was pretty sure that second one was all wrong.  That was a spare anyway so you might just see it for sale soon  ;) ;D
The twin plugger, although not the correct one may just do the job.  Plus I will have the bonus of the "warm up plug" system.  Not building a nut and bolt resto, just a good clean rider.
Unfortunately it looks like it might be a bitsa.  Hopefully most of the remining stuff is correct or I will get crankier than I already am  >:( >:( >:(
Maybe I should just sell it now and cut my losses  :-\
« Reply #20 on: February 21, 2012, 07:24:22 am »
Nah, it's a well known fact that you need to buy 3 extra 'parts' bikes to restore the one you start with
Offline YZ250H
« Reply #21 on: February 21, 2012, 07:38:12 am »
True, I suppose.
At least it will be a runner once assembled  ;D ;D ;D
Offline Ted
« Reply #22 on: February 21, 2012, 09:22:32 am »
Or you could farm it out to someone that can actually fit a gear lever correctly :'(
Offline YZ250H
« Reply #23 on: February 21, 2012, 09:35:13 am »
Nah, that would make my resto's too expensive Ted  ::).  Touche  ;D ;D ;D
Gear lever lesson learnt well and truly.  When you've got half a day to spare I will tell you all the other lessons I have learnt from screwing up things on projects  ::)
Generally it is "always check the easy things first".  Like checking for a leaking valve before you grab the tyre levers to pull the tyre off  ::)  Gear lever is another example.
Maybe I should write a book.  "VMX restoration for the mechanically challenged"  ;D
« Reply #24 on: February 27, 2012, 08:43:21 pm »
OK Ive given you a bum steer ,finaly got to the shed mmmmm forked up Iain ( note to self check first before opening trap hole ) the Yz c 250 only has one plug hole its the 400 that has two . sorry for the bum steer YZ250H . Iain  :-X :-X :-X :-X :-X
Offline YZ250H
« Reply #25 on: February 28, 2012, 06:53:42 am »
No worries whatsoever Iain.  Thanks for your help.
Now confirmed 250 C is one plug hole.  400 has 2.
First head is ???  Second one is YZ250D ??
« Reply #26 on: February 28, 2012, 09:06:27 am »
Was the head originally a twin-plug head, or a single plug head that's modified?
The way the second plug sits under the long fin suggests its modified - usually Yamaha would give lots of clearance around the fin - which would cut the fin entirely.
Edit: Ignore the above. It's MX250B.
The parts picture at Yamaha-motor.com clearly shows two plugs (with one slipping under the long fin), and no fins cut for exhaust clearance.
The pic is here: http://partstream.arinet.com/Image?arik=BuIO8rMsKpZ4DQ063ygX&arib=YAM&arim=iPJ6VgYfK1nym6YvnClJQw2&aria=zDANmFQpUd7dhdhylcHqvQ2&ariz=1&ariv=http%3A%2F%2Fwww.yamaha-motor.com%2Fpartviewer%2Fdefault.aspx%3Fls%3Dsport , but it will some up as "bad request" if you click on the link...
DT250B+ are all sinlge plug, and have fins cut for the exhaust.
YZ250C is single plug.
Same source confrims that the second head is YZ250D.
« Last Edit: February 28, 2012, 09:16:29 am by Nathan S »
Offline YZ250H
« Reply #27 on: February 28, 2012, 06:40:59 pm »
Mystery solved.  Thanks guys.
I might clean them both up and sell them for a deposit on a 250C head  ;D ;D
