Author Topic: Montesa enduro  (Read 1006 times)
Taka 100
Re: Montesa enduro
« Reply #1 on: February 08, 2012, 03:19:16 pm »
already looked at the bike in port early this morning wheels , spkes stainless bit of corrosion on nipples good frame good tank solid cap seized great airbox and 1 side plate ,footpegs ,large bolts , levers and nuts good  motor in bits needs big end and probably rings .front forks couple of large pits on sliders , shafts rusted on shocks
bore and piston good (was quoted $600 to assemble and rebuild motor from one of the better engines builders) gears and insides look unworn 11/76 250 on compliance plate
good side stand and pegs pipe header good thread with chamber in reasonable nick just bit flat on bottom , good mikuni card prob 34mm all in all lot of good stuff and he will take 300 cash if you come and get it soon
