Author Topic: '74 TS250 Questions  (Read 19373 times)
Tony T
Re: '74 TS250 Questions
« Reply #45 on: March 13, 2012, 07:31:42 am »
I was watching that one too, Simo. Looks like a good deal.
Keep us posted on what you do with it.
Simo63
« Reply #46 on: March 13, 2012, 08:08:39 am »
Will do mate.  It actually belonged to one of my best mates but as I'm in Qld and he's in NE Vic I didn't even know he had it let alone that it was for sale.  Just searching through ebay for a 74 or earlier one and spotted it.  I recognised the background straight away, then noticed his user ID and called him.
After I won the auction I called him up and he told me he had a second one for spares that I could have for $90 so I grabbed that as well.  Apparently it has a really good set of alloy rims on it plus of course the rest of it for spares.
Looks like a lot of fun ..... I'm excited  :)
Tony T
« Reply #47 on: March 13, 2012, 09:41:38 am »
If you want sell any of the lights etc, send me a pm.
« Last Edit: March 13, 2012, 01:11:56 pm by Tony T »
Offline topari
« Reply #48 on: March 13, 2012, 10:19:11 am »
........some old pics (the only ones I have ) of my '72-'74 TM/S project. PE seat, TM wheels, TD ag bike tank, modified DT radial head, it now has an alloy airbox using PE rubbers and cage. Made out of bits that were kickin' around.I have also fitted european style vinyl side covers. ;D ;D ???
                                                               Roger
Nice forward mounted rear shocks. Did you perform the modification yourself ?
topari
1979 IT400F, 1984 kdx200
Offline topari
« Reply #49 on: March 13, 2012, 10:55:34 am »
I reckon this bike will look really good when completed. Simple, clean and functional. What more does one need from a trail bike.
topari
« Reply #50 on: March 13, 2012, 12:14:26 pm »
"whats more does one need Topari " ?  An unrusted motor i'd say  .....
TM BILL
« Reply #51 on: March 13, 2012, 12:21:56 pm »
Simo if the alloy rims are original its probably a 1976 A model , a much better starting point for a VMX racer  ;) I think Suzuki used up all the leff over TM 250 parts on the A models .
Simo63
« Reply #52 on: March 13, 2012, 12:57:04 pm »
Thanks Bill, that is very interesting.  Am I allowed to use the 76 parts (frame etc) on a pre 75 race bike or do I have to stick with a pre 75 stamped frame?
If I can then I was thinking of building 2 bikes, one MX'er and one Vinduro mount.
TM BILL
« Reply #53 on: March 13, 2012, 02:55:19 pm »
I only have a 2008 MOMs book  ::) where it says only upto L models ie 74 models .
But i think they were revised recently ( not 100% sure ) to include 76 TS A models in pre 75  ???
Either way run your 74 L model frame as in your photo and motor , but run the A model wheels , footpegs , Engine outer cases , and TM style Rack and pinion clutch actuator ( fitted to A models ) .
The 250 A model ran a different cylinder (electrofusion bore and different porting ) so probably not elidgible for pre 75 .
It sounds confusing but you have a basis of both a good Vinduro mount and a pre 75 250 racer  :)
Simo63
« Reply #54 on: March 13, 2012, 03:42:28 pm »
Thanks TM Bill, sincerely appreciate your advice  ;)
WIN   ;D 8)
TM BILL
« Reply #55 on: March 13, 2012, 04:59:08 pm »
Those TS 250s were over engineered , std thay are a bit heavy but you can shed most of that with a bit of thought  :)
But the motors are indestructable ;D
Tony T
« Reply #56 on: March 13, 2012, 05:22:12 pm »
Really.......  ???
Offline YUMASTEPSIDE
« Reply #57 on: March 13, 2012, 10:06:12 pm »
.........gee, freaky, maybe its a DUMMY motor just for setting up?? ::) ::) ;D
                         non-dummy Roger   ;)
      p.s.  Tony, those pics are on their way once I work how to zip them
« Last Edit: March 13, 2012, 10:08:53 pm by YUMASTEPSIDE »
Tony T
« Reply #58 on: March 13, 2012, 10:21:56 pm »
No problem, Rog.
I don't know how to do that either, so if you want to send via You send It, let me know and I'll give you my log in details.  ;)
« Reply #59 on: March 14, 2012, 12:48:48 pm »
                         non-dummy Roger   ;)
well it makes the pictures look like a skip pull.  At least fit a cover to the clutch.   I just dont have any imagination. :D
