Author Topic: Stubborn Fork Seal  (Read 3640 times)
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
Stubborn Fork Seal
« on: February 07, 2012, 06:02:51 pm »
Hi Guys,
I have a stubborn fork seal which is doing it's best not to be removed. I've tried levering it out with a large regular screw driver, pulling it out with a spring puller but no go. Any more force and I am worried I might damage the alloy where it is seated. Is there a 'Trick' to this I don't know about or have forgotten?
Kenneth S
Go For It
Race Bike History
Re: Stubborn Fork Seal
« Reply #1 on: February 07, 2012, 06:35:41 pm »
Warm it up with a heat gun young  fella  ;)
« Reply #2 on: February 07, 2012, 07:02:54 pm »
And use a tyre lever, not a screwdriver.
« Reply #3 on: February 07, 2012, 10:42:43 pm »
Set fire to it and burn it out with a propane touch.
« Reply #4 on: February 07, 2012, 11:11:17 pm »
It's not a witch hunt Freaky. ;D
« Reply #5 on: February 07, 2012, 11:51:16 pm »
fork it that will sort the little prick out, id even give it a warning... come out or im burning you out !
Offline vmx42
« Reply #6 on: February 08, 2012, 07:40:40 am »
...or you can reassemble the fork without the springs [and without the seal retainer/circlip]... fill completely with fluid and then put the fork in a hydraulic press and carefully compress... the seal will simply pop out.
You don't need to fill the fork in it's fully extended position. You only need an inch or two of travel. Just make sure there is no air in the fork...
or you could have the fun of burning it out... Freaky style!!!!  ;D
« Reply #7 on: February 08, 2012, 07:47:36 am »
Cut into the sides of the seal with side cutters and then lever it out trying to get it folding were you cut.
Remove all retaining circlips compress assembled forks with a tie down and put allot of compressed into the bolt hole at the bottom of the fork.
Offline Noel
« Reply #8 on: February 08, 2012, 08:13:08 pm »
Get a flat punch and go around the Circumference tapping down so the seal collapses inward away from fork
then use tyre lever with protection on fulcrum
 heat is good too ;D
bigger Hammer?
Noel
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #9 on: February 08, 2012, 09:33:17 pm »
Thanks guys, the heat and the tyre lever did it.
Oh and thanks oldfart for calling me young fella!
Kenneth S
Go For It
Race Bike History
« Reply #10 on: February 08, 2012, 11:41:22 pm »
C4
« Reply #11 on: February 08, 2012, 11:49:31 pm »
I was getting kind of stuck on the idea of just torching it  ::) But I got to admit that C4 sounds pretty dam persuasive Tim  ;D
