Author Topic: Porting a 360 H7 cylinder  (Read 5510 times)
Offline jurado
« on: February 07, 2012, 07:25:37 am »
This is a post explaining the porting done on my 360 h7 cylinder, with cappra 414 piston.  Sorry it is it Spanish, but pictures are self-explanatory.
Work basically included:
- polishing and widening intake manifold and intake cylinder ports
- polishing and widening transfers ports facing crank and cylinder
- opening and slightly raising exhaust port
- polishing and widening exhaust manifold
Result is a motor with significantly improved response throughout all the rpm range.
Regards,
http://www.tumotoverde.com/index.php?option=com_fireboard&Itemid=124&func=view&id=133482&catid=6&limit=30&limitstart=0
Re: Porting a 360 H7 cylinder
« Reply #1 on: February 07, 2012, 09:37:09 am »
Where is you get the right angle air grinder?
Sorry but 'polished' surfaces do not flow as well as a rough surface.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #2 on: February 07, 2012, 04:32:28 pm »
The only surface we polish is the exhaust port. I leave the intake and transfers rough,
only matching the ports with the liner. We learned years ago that a rough surface flows
better than a smooth. Race car guy's have known this for a long time.
Offline jurado
« Reply #3 on: February 07, 2012, 10:54:02 pm »
I´ve seen people in favour of and against polishing (i.e. leaving it rough), reading all sort of theories. I guess the only way to right know is to analyse the cylinder in a flow chamber and see flow pattern. The other way would be to do a power test and get the power curve with and without the polishing.
But in my case, I have experience a significant improvement in motor response which, at the end, is the real proof
Regards,
ChrisACT
« Reply #4 on: February 07, 2012, 11:06:57 pm »
Regards,
Even with the dyno readout, does that prove the cause of the change in power?
As I understand it, polishing does improve flow but reduces turbulence and therefore atomisation of the fuel.  So polishing transfer ports might decrease power due to a less efficient burn of the mixture but that doesn't necessarily mean it has decreased flow.
« Reply #5 on: February 08, 2012, 07:50:46 am »
Regards,
Dyno or drag strip is the only way to gauge an unbiased result of modifications to an engine
Trust me leaving it rough works best here's why. If I sat 2 sheets of glass on top of one another  then attempted to push the top sheet of glass would that move easily? Would move but it would take considerable force to over come the friction, if you introduced oil between the glass it would move a lot easier but you have to overcome viscous friction. Last if I tipped a some beach sand between the glass you would find the glass moved very easily as the sheets are held apart and it can 'roll' on the grains of sand. The principal is the same with airflow , the rough surface energies the boudry layer.
http://en.wikipedia.org/wiki/Cylinder_head_porting
maico police
« Reply #6 on: February 08, 2012, 07:54:28 am »
Just enjoy your bike Jurado  8). If you get into any drag races and your not winning just tip some sand down the barrel..... :D
ChrisACT
« Reply #7 on: February 08, 2012, 01:55:43 pm »
Regards,
Sorta like the golf ball dimple effect?
Offline jurado
« Reply #8 on: February 08, 2012, 06:50:59 pm »
Thank you all guys for sharing your views. We also had long time ago these discussions when preparing race cars here in Spain.
In any case, in my view there are many other aspects in our old Montesas with significantly more influence on engine power and response (i.e. carb tuning, ignition timing, exhaust pipe, etc) that polishing or not polishing intakes and transfer tunnels. Definitely, there is clear consensus on the exhaust port.
Regards,
