Author Topic: Needle Bearing KLX 250 1980 ???  (Read 3293 times)
Muecke
« on: March 19, 2008, 08:38:29 am »
Hi,
does anybody know if the needle bearings of the swingarm of the kawasaki KLX 250 1980-81 (size 20x27x25mm) are the same like
needle bearings in any KX from 1978-xxx ????
the original spare part number of kawasaki ist 92046-1001 !!
Thanks for your answering.
Regards from Germany.
Muecke
Offline vmx42
Re: Needle Bearing KLX 250 1980 ???
« Reply #1 on: March 19, 2008, 02:57:10 pm »
HI Muecke,
Yes the bearings in the KLX are the same as the 78/79 KX125/250. They are very hard to find, so if you locate some I suggest you grab them [and if you find an extra set I will happily buy them from you].
They do come up on eBay occasionally. Ken Smith just found a set in the US and it brought a big smile to his face.
I have been doing a bit of work on my 84 RM125 resto and it seems that the bearings are the same size as the Kawasaki. Pivot Works lists a kit for the RM but not the KX [or KLX]. I will be ordering a set in a few days and will let you know what I find [but I am hoping the bearings will be suitable].
VMX42
Muecke
« Reply #2 on: March 19, 2008, 08:40:12 pm »
:) that would be nice hearing from you again!
I will contact you when I could get some in future!!! I won't forget you.....
Offline gtmpaul
« Reply #3 on: March 27, 2008, 07:49:28 am »
Hi, they are still available in the UK
I changed mine last year. Cradley Kawasaki had them in stock
Paul
Muecke
« Reply #4 on: February 03, 2009, 02:33:58 am »
hi,
I have some problems to put the swingarm and the needle bearings together again, after replacing the needlebearings.
I only have a bad copy of the service book. There I cannot find out how the needles, the oil rings and the sleeves should be.
I have the problem that the swingarm does not match in the frame because it is too wide.
Can anybody post a foto or give me some details of the service book in good quality?
Thanks a lot
Bye
Sven
