Author Topic: Info required for Yamaha IT forks.  (Read 2991 times)
Offline mudguard
« on: February 05, 2012, 08:38:11 pm »
Just need the correct info for the following questions?
Was there a 1977 model IT 175?
If so, are the forks for the 175, the same forks on the 250 & 400 for 1977 models?
What is the total length of the forks and are they 36mm diameter?
Any help would be appreciated.
Cheers.
Offline the stig
Re: Info required for Yamaha IT forks.
« Reply #1 on: February 05, 2012, 08:51:07 pm »
      My 1977 it 175 Forks   are 36mm.   900mm overall  820mm from the axle to
      the top of the Fork leg..
      not sure what sizes 250 400 have on them.. .
      The  Stig..
Offline mudguard
« Reply #2 on: February 07, 2012, 08:27:36 pm »
Thanks, the stig. That info will help.
So does anyone know if the forks for the 1977 IT250 & 400 are the same as the IT175?
Where are the IT guru's when you need them?  :D
« Reply #3 on: February 07, 2012, 10:49:12 pm »
I have got what i think are them forks here.  IS any one interested in buying them ? i have no use for them as ill my stuff is 34 or 35 mm.
valleyam
« Reply #4 on: February 08, 2012, 06:06:13 am »
if you want info about IT yamaha go here http://www.yamahait.com.au/forum/index.php
« Reply #5 on: February 10, 2012, 11:34:25 pm »
IT250/400D forks are 36mm.
I think they're longer overall than the 175 forks, and may have different lower legs, but wouldn't bet money on it.
