Author Topic: alloy swing arm..whats it from  (Read 3375 times)
Offline Davy123
« on: February 01, 2012, 05:39:38 am »
Offline Frank M
Re: alloy swing arm..whats it from
« Reply #1 on: February 01, 2012, 06:21:04 am »
looks like RM250/400 1978
Offline BAHNZY
« Reply #2 on: February 01, 2012, 08:17:13 am »
Albeit heavily modified.
Rod (BAHNZY) Bahn
Offline bazza
« Reply #3 on: February 01, 2012, 10:09:38 am »
RM370 with alloy swingarm (some had steel) the 78 suzuki was a little bent on end this seems straight
Mark FX swingarm expert of the gods should know
Embrace patina
« Reply #4 on: February 01, 2012, 12:04:10 pm »
Looks like a butchered RM c swingarm with different shock mounts and rear axle mount. All rm370's had steel swingarms.
Offline BAHNZY
« Reply #5 on: February 01, 2012, 12:51:27 pm »
These arms are very popular with some of the hybrid conversions being done, I think that some of the TT500 conversons may have used them. Either way someone has taken away the through bolt system for the OEM chain guide and welded in the nutserts for a different type of chain guide and the original shock mounts have been completely removed with new one's fabricated and fitted futher outbound on the arm. There is also a diffrent style chain rubbing block and what appears to be a bracket welded to hold it in place.
Rod (BAHNZY) Bahn
Offline Davy123
« Reply #6 on: February 04, 2012, 05:22:54 am »
Well it arrived ..its not an RM suzuki one at all its  TGM item...unbelievably its the same make of frame i used in one of the bikes i own  ;D
