Author Topic: coils  (Read 2201 times)
Offline shortshifter
  • Sunshine Coast QLD
coils
« on: January 31, 2012, 08:16:46 pm »
Hi anyone got any working CZ coils they aren't using.need for a dual coil ignition 250.tony 27 just reading your TS ignition thread.Was the piston holing itself an ignition problem or something else?
Re: coils
« Reply #1 on: January 31, 2012, 08:36:03 pm »
When I stripped the motor to flush all the bits of piston I discovered that there wasn't much in the way of sealant left at the bottom of the cases so it was probably sucking air as well the timing being set a bit a bit too advanced
I rebuilt the engine with a new piston kit & rebored the cylinder which it needed anyway.
I made sure to use a cotton thread in the sealant( no silk as stated in the manual) as insurance against the same thing happening again
Sudman came around 1 evening & we timed the motor to fire at 3.5mm at maximum advance to be safe, really need to do some proper testing on the timing at some stage to see where it can be moved to
So far it's run like a train since the rebuild & really jumps out of corners, starts easier & idles better as well
If you need any info I'm more than happy to help out
