Author Topic: Identify these ???  (Read 2300 times)
TM BILL
Identify these ???
« on: January 30, 2012, 01:45:12 pm »
Can anybody identify what this backing plate and brake shoes are off thanks Bill.
Offline David Lahey
Re: Identify these ???
« Reply #1 on: January 30, 2012, 02:32:55 pm »
Looks like Bultaco something rear. What is the OD of the shoes and the axle hole?
previous pseudonym feetupfun
TM BILL
« Reply #2 on: January 30, 2012, 03:15:29 pm »
OD of shoes when assembled onto backing plate is approx 5.5 inches or 138mm
Axle hole is 17mm approx
Offline David Lahey
« Reply #3 on: January 30, 2012, 04:17:15 pm »
That backing plate you have is the same as what I have on the rear of my M138 Alpina. My hub is the two-piece rear hub (brake drum on opposite side to sprocket) as fitted to Pursangs and Alpinas after about 1973 or 1974 and also to Fronteras.
I suspect that same backing plate you have may also fit the one-piece rear hubs (brake drum and sprocket on the same side) fitted to earlier Pursangs and Alpinas, but not the very early rear drums that have twin brake shoe pivot posts and wider shoes.
TM BILL
« Reply #4 on: January 30, 2012, 04:43:18 pm »
Thanks for that any idea where i can get some brake shoes ? cheers Bill
Offline David Lahey
« Reply #5 on: January 30, 2012, 06:23:22 pm »
Peter Schoene in Victoria (Bultaco Parts Australia)
Don Newell in Brisbane
Bultaco Parts UK
or get them relined at your local brake shop
Offline BultacoMacca
« Reply #6 on: January 30, 2012, 11:11:36 pm »
I know you can get front shoes from EBC, not sure about the rears.
