Author Topic: Ktm rear hub - not vintage  (Read 2491 times)
« on: January 29, 2012, 07:29:28 pm »
Looking for a rear hub to suit a 97 ktm300. I think the hub was the same for all capacities though
Offline YZ250H
  • Back in QLD Baby !
Re: Ktm rear hub - not vintage
« Reply #1 on: January 29, 2012, 07:56:47 pm »
What's wrong with the one you got ??
« Reply #2 on: January 29, 2012, 08:01:01 pm »
looks like Hannibal Lecter has been let loose in there with a dremel.
I knew it wasn't going to be good when the bearing and seal fell out with the spacer ;D
« Reply #3 on: January 29, 2012, 08:06:37 pm »
Believe it or not, I have a NOS front one. ;D
Offline YZ250H
« Reply #4 on: January 29, 2012, 08:09:11 pm »
The way the back one is Davey he may be needing the front one as well  ;D ;D ;D
Obviously you have checked ebay  ::)
« Reply #5 on: January 29, 2012, 08:13:11 pm »
 Paul , though about using a speedi sleeve.
« Reply #6 on: January 29, 2012, 08:16:28 pm »
I did, but it's pretty flogged out in there, probably too much for a speedi-sleeve. If I can't find a hub I might have to get it bored out and have a sleeve made up.
Tony T
« Reply #7 on: January 29, 2012, 08:19:20 pm »
Apparently, that's quite common problem with that era KTM's.
So you might struggle to find a good S/H one.  :-\
« Reply #8 on: January 29, 2012, 08:22:27 pm »
I've heard the same, might be a trip to the machinist
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #9 on: January 29, 2012, 08:28:52 pm »
i was going to suggest you get the bearing "built up" with a copper coating.
but if it's too flogged for a speedi sleeve, then ???
"flat bickie"
Offline SLAWESY
« Reply #10 on: January 29, 2012, 09:24:22 pm »
CLASSIC!!
YZ125E, RM250T
Is it way too small? A bit of work with the heat gun or hot water could soften it enough to fit if it's close. Maybe some rubber friendly grease as well.
Mainline "classic"
« Reply #11 on: January 29, 2012, 09:57:37 pm »
Turd!
Offline ian
« Reply #12 on: January 30, 2012, 08:31:18 pm »
there is a 99 ktm rolling chassie ebay  120852059221 if its any help
Offline ola_martin
« Reply #13 on: January 30, 2012, 09:38:54 pm »
And usually happens because the chain is too tight.
