Author Topic: rm250 engine cases  (Read 3070 times)
geoff22
rm250 engine cases
« on: March 18, 2008, 04:36:15 pm »
Hi guys . I have started a restoration on RM250E and have just noticed that the bottom engine mount hole in the cases has elongated. Does anyone have any ideas on what I can do? should I worry or not. Should I try and source another set of cases? All the other engine mounts are in good shape
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: rm250 engine cases
« Reply #1 on: March 18, 2008, 04:47:28 pm »
Don't worry about it just use spring washers and nyloc nuts and make sure they are torqued up nice and tight
Ban BLACK rims NOW
Doc
« Reply #2 on: March 18, 2008, 05:04:36 pm »
If it was bad and there was enough material around the hole I'd bolt the cases tightly in the frame and then bore a nice new hole and up the size of the bolt. If it's not bad do the above and keep a check on it. Also check the inside side clearance..chances are if it (the motor) was real loose it's not only elongated the hole but the cases maybe a fraction narrower now too :o in the day suzuki recommended shimming this gap between the cases and the frame with suitable flat washers or shims as they referred to them ;)
Offline suzuki27
« Reply #3 on: March 21, 2008, 09:45:44 am »
I remember reading an article about the RM250T-which I had just bought new-and the engine mounting bolts were of a smaller diameter to the case holes.This,they said,was the cause of some broken engine mounts.As the other guys have stated,drilling out and going larger or shimming out -both will work.I just rebuilt a 125D with ovalled front engine mounts and worn cases from the movement here-I just shimmed it out and used nyloc nuts with loctite and all good for about 2 years now.
Offline caps 999
« Reply #4 on: March 21, 2008, 10:26:34 am »
why noy drill the mounts out and fabricate a bronze bush
MUGEN power
Doc
« Reply #5 on: March 21, 2008, 06:32:30 pm »
cause that's too much trouble :P unless of course you have a lathe in the garage..that would help  :)
