Author Topic: '77 PE250B original rear tyre fitment  (Read 3263 times)
clutchslip
« on: January 27, 2012, 04:43:33 am »
Hi all,
Looking over a very clean original B model today, that was fitted a very worn IRC with 'Pure Enduro' embossed in the rubber near the bead of the tyre, which is on an Akront rim; is this just a coincidence, or could it be that the bike is on its original rear tyre? The bikes speedo is reading less than 300 miles which might also back this up, although I don't know if it is working. Thanks a lot, Mac
« Last Edit: January 27, 2012, 04:46:53 am by clutchslip »
Le Canari
Re: '77 PE250B original rear tyre fitment
« Reply #1 on: January 30, 2012, 06:54:03 pm »
hello
yes IRC tyre is original !
for rim   i dont sure  but  i think  the original is  TAGASAGO  rim ( PE 175 CNTXZDE PE 250 CNTXZ   PE 400 TXZ )
argh  pe250 B  is may dream
le canari
clutchslip
« Reply #2 on: January 31, 2012, 03:49:57 am »
Hi Canari, thanks for the info. The full script on the tyre reads 'Pure Enduro IRC Volcano'. Thanks Mac
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #3 on: January 31, 2012, 05:43:02 am »
Yes! the earliest of the PE250B's came with Akront rims (later the Takasago rims became standard) and a 'wears like iron' IRC tyre specifically done for it, which I have seen referred to as the 'Volcanduro' and 'Volcano'. So it sounds original. Is the front an IRC GS 565 perchance?
Luke
« Last Edit: January 31, 2012, 06:15:17 am by lukeb1961 »
clutchslip
« Reply #4 on: January 31, 2012, 06:32:26 am »
Hi luke, script on front tyre actually reads IRC Motocross GS-56 F, rather than GS-565. I initially thought that was a later replacement, but your number is so close perhaps it sounds like it could be original too? Should also have added thaat the bike is an early one, frame number puts ite within the first 100 bikes made. All the best, Mac
« Last Edit: January 31, 2012, 06:36:42 am by clutchslip »
Offline lukeb1961
    • PE175N
« Reply #5 on: January 31, 2012, 08:05:45 am »
Yeah, that sounds original!
Photos please  ;D
Le Canari
« Reply #6 on: January 31, 2012, 09:40:49 pm »
Luke
hello luke  ;)
ok thank you for information  8)
Akron rims are fitted on all PE 250 B  or just the first series??
thank you my friend
le canari
Offline lukeb1961
    • PE175N
« Reply #7 on: February 01, 2012, 07:42:31 am »
Hello Fabrice  ;D
Just the very first 250B's - a few hundred and then they changed to Takasago for everything.
You will have to start collecting your PE250B parts once the 250N is done!
Luke
Le Canari
« Reply #8 on: February 01, 2012, 08:18:46 am »
thank you luke
yes  when PE 250 N is finish  , i search part for PE250 B  :P
le canari
