Author Topic: Beamish 325 RL Silver motors  (Read 8009 times)
Offline YUMASTEPSIDE
« on: January 25, 2012, 09:19:03 am »
Does anyone have any info on the Beamish 325 conversions on the early suzuki "silver" motors. Do they use standard barrels? Stroked crank? Are the pistons / rings still available?
  Any articles or info would be appreciated.
                   Roger
Montynut
Offline djr
Re: Beamish 325 RL Silver motors
« Reply #2 on: January 25, 2012, 10:40:02 am »
you could also try   www.beamishownersclub.com     {lots of usefull info}
« Reply #3 on: February 06, 2012, 07:32:38 am »
Lots of info,thanks.........but not much technical stuff.  ???
  I'm trying to find out how they turned a 250 into a 325? Does the 325 sleeve fit a standard early barrel, did they change the crank or rod ?
                               Roger
Offline djr
« Reply #4 on: February 18, 2012, 09:45:36 pm »
Hello, I am probally wrong but i havent seen or read about any silver engine 325 beamish bikes. The only 325s i have seen had the black engine which was supposed to have been made as a 325 .{ 250 black engines are fitted with an extra liner bringing them down to 250cc  and some differance on cyl. heads to get correct compression ratio} I think several people have converted a black engine 250 to a 325 by removing the liner , new piston & altering compression with machining or extra gaskets.
The black & silver engine 250s have same bore & stroke 70x64 .The 325 is 80x64 so only differance is bore size wouldnt think crank or con rod are any differant.
Anyway i expect you allready know all this , i think there is a thread on this subject  on the Trialscentral forum somewhere.
if i find any more info i will put it on here
dave
« Reply #5 on: February 21, 2012, 08:40:29 am »
From what I've read, the "silver" motors were the first of the RLs, basically an early TS motor,maybe '72 to '74.
                         Roger
« Reply #6 on: February 24, 2012, 12:47:36 pm »
.........Beamish " silver motor " RL.
                                    Roger
Offline David Lahey
« Reply #7 on: February 24, 2012, 05:25:37 pm »
Yes based on TS motor. I wonder why they made the RL exhaust port go the other side to the TS motor?
previous pseudonym feetupfun
