Author Topic: Shocking advice  (Read 9503 times)
Shocking advice
« on: March 17, 2008, 07:54:17 pm »
I am doing a pre '78 resto and need to find a pair of shocks, without having the originals to measure from I will be guessing the length of standard shocks, so my next option was to find how shock travel is measured by MA for the pre '78 class, this will at least give me a starting point.
Anyone a scrutineer?.........or have a set of phantom gp2 betors lying around that they could measure eye to eye.
Recommendations for aftermarket shocks ?
Re: Shocking advice
« Reply #1 on: March 17, 2008, 08:25:47 pm »
page 156   18.7.7.1  a)    regardless of original specifications no motorcycle may have more than 229mm ( 9'') of suspension travel at front and rear wheels
Offline jimson
  • Sanctuary point N.S.W
Re: Shocking advice
« Reply #2 on: March 17, 2008, 08:33:59 pm »
Yes YSS shocks you talk straight to the man 8)  and they help you with all your needs and there right here on Aussie soil  ;D jimson
YSS
Re: Shocking advice
« Reply #3 on: March 17, 2008, 08:34:28 pm »
What brand and model motorbike is it ? We have most specs for pre 78 .  Ones your specs are established ,you can then choose the type of shock(s) you need, depending on your needs and budget.
Cheers Walter
Re: Shocking advice
« Reply #4 on: March 17, 2008, 09:05:13 pm »
ossa phantom gp2 '76
YSS
Re: Shocking advice
« Reply #5 on: March 17, 2008, 09:14:19 pm »
According to my specs , they need to be 340 CTC.  Does anyone have a different spec ? Ossas are not an everday item in Australia . Its all the different brands and models that ad the spice to VMX.
Offline pmc57
Re: Shocking advice
« Reply #6 on: March 17, 2008, 10:56:07 pm »
YSS, I have a pair of original RM250B remote resevoir type shocks. Are these units rebuildable, if so what methods used to open them up and repair/rebuild, my understanding is that they are a sealed, non-servicable unit. Are they gently cut open then rewelded??
YSS
Re: Shocking advice
« Reply #7 on: March 17, 2008, 11:16:33 pm »
They have to be cut  and then caped , but you will loose about 6 mm in total lenght. So unless you want to restore it to original condition , new shocks are a better , quicker and usually a cheaper option . ( a new set of E302 for the RM B is only $450.00 a pair )
« Last Edit: March 17, 2008, 11:23:23 pm by YSS »
Offline holeshot buddy
  • sunshine coast qld
Re: Shocking advice
« Reply #8 on: March 17, 2008, 11:25:17 pm »
hey walter how did you go with my rm370 shocks i hope big al has sent them
rusty......
follow me to first turn
YSS
Re: Shocking advice
« Reply #9 on: March 18, 2008, 12:05:16 am »
As far as I know , big AL has it under control. Perhaps give him a call.
Offline pmc57
Re: Shocking advice
« Reply #10 on: March 18, 2008, 12:12:05 am »
YSS, I think I buggered up my last message I sent so i'll ty again.
What are the telltail signs that these shocks have been opened up and rebuilt? I've tried adjusting the dampening on these units but are unable to hear the clicks that you listen for in the adjustment process. They seem to have a weld bead about 25-30mm down from the seal area. Would this be where they were opened up and would opening them up loose the dampening adjustment capability??
YSS
Re: Shocking advice
« Reply #11 on: March 18, 2008, 12:19:38 am »
Can you send a pic ? then I can tell you for sure
Offline pmc57
Re: Shocking advice
« Reply #12 on: March 18, 2008, 12:28:47 am »
YSS, They're back on the bike, I'll have to remove them and pull the springs off. I might do it later in the week, it's too late now, I'm off to get some sleep.
