Author Topic: sp370-sp400  (Read 3615 times)
Offline tmman
sp370-sp400
« on: January 22, 2012, 11:27:44 am »
does any one have a wiring diagram for sp370 and or sp400 you could send me or point me in right direction ..also still chasing rm250-400 78.5 swing arm wheel adjusters will consider complete arm if you don;t want to seperate...thanks
Offline bazza
Re: sp370-sp400
« Reply #1 on: January 22, 2012, 11:28:58 am »
sure i got one on google-1 of the suzy shops has info from memory,otherwise PM Stew (old Fart) for lead
Embrace patina
Re: sp370-sp400
« Reply #2 on: January 22, 2012, 12:02:08 pm »
Tm man I have a clymer manual with a wiring Diagram in colour ...  covers Dr 370 c /n    Dr 400 t   Sp 400 t.
Offline tmman
Re: sp370-sp400
« Reply #3 on: January 22, 2012, 01:43:29 pm »
i have checked there site n tryed there data base to find comes up with zero. can you tell me whats written on cover. are you able to scan and email to me??? thats all i need from the book.. thanks
Offline cloggy
Re: sp370-sp400
« Reply #4 on: January 23, 2012, 08:37:38 pm »
 I've got a pdf file of the manual. I regularly e it to anyone who asks. PM me
 I have that swingarm in a DR400 frame. I think it goes in to the SP frame with the same mods. Sleeve the inside of the pivot with tube to take it up to the correct width and reinsert the SP sleeves bearing pin etc. On the DR ideally it needed to be offset a few mm but it works fine set up centrally. All parts for the chain tensioner came straight from suzuki. But they did send the wrong spring. There were 4 on ebay so sorted.
Possibly worth a try to see if the parts you need are still in stock too.
« Last Edit: January 23, 2012, 08:49:11 pm by cloggy »
Tony T
Re: sp370-sp400
« Reply #5 on: January 23, 2012, 09:02:30 pm »
Just a note that the '78 SP frame has a smaller swingarm bolt and front/lower engine mount bolt than the '79 mode frame.
Whatever that info is worth...........  ::)
Offline cloggy
Re: sp370-sp400
« Reply #6 on: January 24, 2012, 12:42:18 am »
 The DR wheel spindle is bigger though the width is about the same. I had to grind off the wheel adjuster clampbolts to get everything to fit
Offline tmman
Re: sp370-sp400
« Reply #7 on: January 24, 2012, 08:11:29 am »
have put motor in pe250 frame [don't try this at home] few tire levers and a large hammer n she went in ok.. i'll pm my deets for manual thanks..
