Author Topic: pe175 query  (Read 4919 times)
Offline suzuki447
pe175 query
« on: January 19, 2012, 06:09:35 pm »
gday ,just getting my pe175x(81)ready for rego ,just got all lights and blinkers working ,yahoo,anyway there is a small plastic covered metal item 20mm x20mmx5mm thick mounted near right side rear top shock mount with two wires to it one orange,(has power thru it)other is white with red stripe,orange goes back into engine(stator i think)other stop near top of battery but has female fitting on it so must join somewhere ,look like a relay or something ,not sure any ideas ,what it is and connects to.maybe light relay.thanks don.manual shows nothing.
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: pe175 query
« Reply #1 on: January 19, 2012, 07:45:23 pm »
Sounds like the resistor you put in series with the regulator to power the lights and protect them from blowing from sudden current surges (missed gear change false neutral etc)
Ban BLACK rims NOW
Offline suzuki447
Re: pe175 query
« Reply #2 on: January 19, 2012, 10:24:00 pm »
thanks mate any idea where white with red stripe wire goes to.i thought maybe back to headlight.
monaro308
Re: pe175 query
« Reply #3 on: January 20, 2012, 08:18:04 am »
From Lukes site....
Re: pe175 query
« Reply #4 on: January 20, 2012, 01:57:07 pm »
Looks like a diode to me.
Montynut
Re: pe175 query
« Reply #5 on: January 20, 2012, 03:10:32 pm »
Lozza is correct it is most likely a single diode (half wave) rectifier or possibly 4 diode bridge (full wave) rectifier. If the bike is wired as per the diagram then unless that white/red wire is connected then the battery will not charge.
The magneto produces AC voltage which varies its frequency with engine speed and also its voltage to a dregree. The rectifier changes that to DC for use in the lights and to charge the battery.
The battery acts as a regulator to a large degree which is why newer bikes without batteries have a large capacitor to smooth the rectified DC.
It is interesting that the fuse will only stop the battery from feeding a fault but the magneto / rectifier can continue to feed a fault in the wiring whenever the engine runs. Do they have problems with burning out magneto? If so that could be why.
« Last Edit: January 20, 2012, 03:14:26 pm by Montynut »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: pe175 query
« Reply #6 on: January 22, 2012, 01:48:18 pm »
Montynut is correct.  rectifier for the battery.
Mine is registered and the (tiny 2AH) battery does charge. Not heard  of issues with magneto burnout. The only issue one ever really encounters with the PE is blown bulbs due to bad earths.
pictured is the rectifier on my '79 PE175N
and below is the YUASA 6N2-2A-4 battery
Luke
Offline suzuki447
Re: pe175 query
« Reply #7 on: January 22, 2012, 06:59:21 pm »
thanks mate .thats the part.should all be ok .can u tell me if headlight and tail lite only work when bike is running.i have all blinkersworking correctly and brakelites right.working off battery.i,m using a sealed 6v 4.5 amp.battery from supercheap.,no spillage and fits exackly in original battery holder.
Offline lukeb1961
    • PE175N
Re: pe175 query
« Reply #8 on: January 22, 2012, 08:49:10 pm »
The headlight and tail are on a separate circuit, as you can see in the diagram.
So yeah, they only work when the engine is running. All PE's regardless of location had these.
Australia specific extras via the battery are the stop light, blinkers and horn.
Note the front brake lever and foot both should be triggering the brake light.
The wiring for them is basically lifted from the TS185.
Luke
« Last Edit: January 22, 2012, 08:50:47 pm by lukeb1961 »
monaro308
Re: pe175 query
« Reply #9 on: January 22, 2012, 11:01:57 pm »
447 when you have a chance,can you post up a pic of that battery?
May be useful for us PE nuts  ;D
cheers...Mario
Offline suzuki447
Re: pe175 query
« Reply #10 on: January 23, 2012, 07:20:02 pm »
sure mate when son get,s back.there available at most battery places or jaycar electtronics,super cheap auto ,bout $20 and they just fit in .
