Author Topic: RT1 Frame needed.  (Read 2202 times)
Offline crossedup2
  • Never enough shed time.....
RT1 Frame needed.
« on: January 16, 2012, 10:08:49 pm »
About a year ago I did some dealing with Nathan S and ended up with his RT1 project. He did some cuts to the frame which could be dealt with but a dfferent original frame would make life easier.
The bottom end is RT2 and I'm not sure if there are any differences between RT1 & 2 or 3 frames. For that matter, I'm not sure if DT1 frames are the same and would be usable??? I need just bear frame and a bit of advise.
Prefered Sydney area if possible.
Peter B
0418 680 264 or email
Re: RT1 Frame needed.
« Reply #1 on: January 16, 2012, 10:18:12 pm »
I've got a straight and original DT1 frame.  It's got some hillbilly lay down shock mounts welded to it but it's otherwise stock and quite usable. PM me with your location and when you want it.
