Author Topic: MONTESA m43 gp5 cappra front sprocket 13 tooth  (Read 859 times)
« on: January 13, 2012, 03:47:22 pm »
need a 13 tooth front sprocket for a 1969 gp5 250 capra any one got one
thanks
jim
SPANISH ARMADA
Re: MONTESA m43 gp5 cappra front sprocket 13 tooth
« Reply #1 on: January 13, 2012, 08:34:20 pm »
jim get someone with a lathe or mill to cut the centre out of yours and bore the centre out of a new 13t sprocket and make it a interference fit so u can press it over old centre makeing sure u keep the same original centreline [so the chain lines up] then get some one to tig weld it up then linish off and sent off to zinc platers [finished].ps if u dont have and old tapered keyway sprocket then give me a ring over the weekend cheers chris
« Reply #2 on: January 14, 2012, 05:59:09 am »
thanks
will do
