Author Topic: CZ 360 1969  (Read 2970 times)
Stormer
CZ 360 1969
« on: January 05, 2012, 07:44:01 am »
Can anyone advise what oil/fuel ratio to use on a cz 360 and which oil to recommend, also what spark plugs to use Thanks
Offline Bamford#69
Re: CZ 360 1969
« Reply #1 on: January 05, 2012, 10:43:26 am »
Hi,
after more than 40 years of racing CZ's twinport, sidepipes,and single port motors, Iv'e found  more oil means more HP and longer lasting engines,
 20 : 1 ,  yes, Twenty to One ,and  Castrol TT,
 NGK  B8HS ,
Taka 100
Re: CZ 360 1969
« Reply #2 on: January 05, 2012, 11:24:53 am »
Hi,
 20 : 1 ,  yes, Twenty to One ,and  Castrol TT,  right on brother thats the money shot the TT is now called 2T same oil different kid designing new labels do they just do that to confuse the frail  ???
 NGK  B8HS ,
Re: CZ 360 1969
« Reply #3 on: January 05, 2012, 11:57:18 am »
i use 20.1 on all my 2t bikes even the ones running on methenol
jim
cz400
cr250
yz125x
Offline foxy999
Re: CZ 360 1969
« Reply #4 on: January 05, 2012, 01:37:15 pm »
my wife and i have the 250 and 360 and they have been runing great as per jikov spec's.  he know's all about these bikes...
My fastest lap is the first one :)
Offline VMX60
Re: CZ 360 1969
« Reply #5 on: January 06, 2012, 12:53:42 am »
Jikov
Do you mean base tt/2t or TTS castrol oil
Last 10 years aways used TTS at 32/1 ratio
B8HS plug
Stormer
Re: CZ 360 1969
« Reply #6 on: January 06, 2012, 07:28:16 am »
Thanks for the info guys much appreciated
Offline Bamford#69
Re: CZ 360 1969
« Reply #7 on: January 06, 2012, 04:18:15 pm »
Hi,
Sorry , the correct label is ; Castrol "Active" 2T m/cycle oil,
ps; Iv'e never tried TTS
Offline shortshifter
  • Sunshine Coast QLD
Re: CZ 360 1969
« Reply #8 on: January 20, 2012, 09:41:59 am »
Have been running 32:1 but will try 20:1 in 360 with new top end.Have been using Fuchs.Is Active 2t a mineral oil?
Offline 35elsinore
Re: CZ 360 1969
« Reply #9 on: January 20, 2012, 08:34:36 pm »
Yes Active 2T is a mineral oil, TTS is synthetic. I have run TTS for fifteen years in cr125, cr250, yz250, kx250 at 40 to 1 with no problems at all. When the engines are pulled down to keep fresh there is always a film of oil through the engine. Makes easy for mixing with half litre of oil for 20 litres of fuel [premium unleaded now]. Hope this helps.
Cheers Troy
