Author Topic: DESPERATE FOR BULTACO STANCHIONS  (Read 10648 times)
« on: December 29, 2011, 09:23:03 pm »
Looking for MK8 or MK9. There's got to be some out there somewhere. Swap one of my children or cash! Jerry
Offline David Lahey
Re: DESPERATE FOR BULTACO STANCHIONS
« Reply #1 on: December 29, 2011, 10:28:17 pm »
I've got enough kids already thanks Jerry but I have just had a quick look and found some second-hand 560mm Bultaco Betor 35mm fork tubes with the knurled section starting 180mm from the end.
I looked up a book and it showed Mk8 Pursang as having in-line sliders and Mk9 Pursang as having leading axle sliders so not sure what you are seeking
previous pseudonym feetupfun
« Reply #2 on: December 30, 2011, 09:43:31 am »
Thanks for replying Feetup. I realise what your saying regarding the axle placement but it is of no concern as it's the stanchions I'm after. Tell me do your stanchions have the tapered end (that fits into the top triple clamp) or the non tapered.
Offline David Lahey
« Reply #3 on: December 30, 2011, 10:47:32 am »
Non-tapered tops. I suspect the ones I mentioned might be from either late model Alpina or Mk7 Pursang because there are sliders of both types in with the tubes. I mentioned the positioning of the knurling because there are also some tubes there that are otherwise the same but with the knurling further down which I think might be Sherpa T, and because I don't know how far apart the triple clamps are on Pursangs.
« Reply #4 on: December 30, 2011, 03:20:06 pm »
Thanks Feetup sounds promising. I will do a bit more research over the weekend and get back to you. Presumably if its a goer they are for sale. Are you able to let me know the condition of the chroming etc. Feel free to PM if you like. Cheers Jerry
Offline Husky Parts
« Reply #5 on: December 30, 2011, 08:05:28 pm »
Hi Jerry,
Go to the Bultaco section, page two and have a look at some Bultaco front forks I am willing to sell  if you are interested.
Thank you
Fernando
Husky Parts
0416198307
« Reply #6 on: December 30, 2011, 08:21:17 pm »
Thanks Fernado but it is the ones with the non tapered end I am looking for. Jerry
Offline David Lahey
« Reply #7 on: January 01, 2012, 09:17:45 pm »
Hi Jerry I just got back from a trip
I'll have a good look at the tubes tomorrow
David
Offline Snowy 76
« Reply #8 on: January 01, 2012, 10:01:59 pm »
No Nothing about Bultaco forks, but when I was getting the forks sorted for the Bandito, noticed stamped in  the tapered section bike model {M18} are thay all stamped ?
Couple of CR`s
Offline David Lahey
« Reply #9 on: January 01, 2012, 10:31:33 pm »
I just looked at eight taper-top bultaco betor tubes and two of them were stamped "18" at the bottom end of the taper. No "M" in front of the "18" though.
I couldn't see any stampings on the other taper-top tubes.
Offline Moto
« Reply #10 on: January 01, 2012, 10:51:55 pm »
Jerry, what bike are you wanting the staunchions for?
You definately don't want Mk 9 forks as they are 38mm
« Reply #11 on: January 01, 2012, 11:40:01 pm »
Thanks Moto I didn't know that. Its definitely 35mm Dia Im after. What I have is the finned in line axle sliders. I believe they were on an early model Frontera and I'm looking for the correct stanchions that should give me 200 mm of travel. I'm advised by Peter Schoener at Bultaco Parts that I need upwards of 560 mm in length and non tapered on the end. If they are too long thats not a problem as I have access to a lathe to cut down and rethread. If you can help I would much appreciate it. Cheers Jerry PS Thanks Feet up (Dave) I look forward to hearing from you. Incidentally one kid is a plumber and the other ones a chippy. Take you pick!
Offline huskibul
« Reply #12 on: January 02, 2012, 06:48:40 am »
     Jerry, the finned 35 mil forks also came on the mk9 125 pursangs (i have them on my mk-5 250) ! maybe the 250/370 were 38, cheers
« Reply #13 on: January 02, 2012, 08:44:39 am »
Thanks Huski would you mind pulling the MK5 apart and selling them to me please!!! Cheers Jerry
Offline huskibul
« Reply #14 on: January 02, 2012, 08:58:20 am »
    Ahhh yeah that will be a negative ! but thanks for the offer jerry   ::)
