Author Topic: TS/TM 250/400 rear spoke and nipples  (Read 3546 times)
« on: March 13, 2008, 08:06:59 pm »
Wanted- TS/TM 250/400 rear spokes from any model below
I need 2 outer rear spokes, one from the drive side and one from the brake side. They are both have approx 85 deg bend but one is longer than the other. I also need 6 original spoke nipples. As long as they are not badly rust pitted they will be fine for me as I will be re-plating them.
email - [email protected]
TM250J 1972
TM250K 1973
TM250L 1974
TM250M 1975
TM400J 1972
TM400K 1973
TM400L 1974
TM400M 1975
TM400R 1971
TS250A 1976
TS250B 1977
TS250C 1978
TS250J 1972
TS250K 1973
TS250L 1974
TS250N 1979
TS250R 1971
TS250T 1980
TS250X 1981
TS400A 1976
TS400B 1977
TS400J 1972
TS400K 1973
TS400L 1974
Re: TS/TM 250/400 rear spoke and nipples
« Reply #1 on: March 13, 2008, 09:59:09 pm »
wow it lloks like any suzuki dirt bike is the same from pre 80's
« Reply #2 on: March 14, 2008, 08:18:46 pm »
yes almost. thats whats good about suzukis. its for my TS 250 1980, and the spokes are same as TM's so i figured theres plenty of guys out there with stashes of TM parts?
by the way the spokes (2) i need are not butted.
im also looking for a fairly good rear hub with good linings aswell, but first i want to find these couple of spokes/nipples
« Last Edit: March 14, 2008, 08:20:34 pm by LWC3077 »
« Reply #3 on: April 02, 2008, 09:38:11 pm »
ok ive found the nipples. all i need now is 2 outer spokes, one from each side of hub if any one has any.
Offline jimson
  • Sanctuary point N.S.W
« Reply #4 on: April 02, 2008, 11:05:19 pm »
LWC I have a wheel here its off a Suzuki but I don't know which model is there a number in the hub that will tell me its the one you want. I will have a look tomorrow its rough but if its what your after its yours.I just want the rim.jimson
« Reply #5 on: April 04, 2008, 08:39:42 pm »
there would be a number but there is no way i can easily get at my hub as its packed away really tight and hard to get at.
i think i might take photos of the spokes with a few dimensiuons and stick them up here
« Reply #6 on: May 04, 2008, 09:35:15 am »
ok finally got the photo of what i need
« Reply #7 on: May 04, 2008, 10:23:19 pm »
are you in adelaide ?
« Reply #8 on: May 05, 2008, 11:22:15 am »
no
« Reply #9 on: May 05, 2008, 11:40:41 am »
well that kills that idea.
