Author Topic: Honda Barrel with KT stamped near exhaust port  (Read 2282 times)
Offline suzuki27
« on: November 29, 2011, 06:46:23 pm »
Anyone know what 2 stroke aircooled 70's Honda barrel had 'KT' stamped on the outside, in beneath the exhaust outlet? CR, MR , MT ??
Offline Noel
Re: Honda Barrel with KT stamped near exhaust port
« Reply #1 on: November 29, 2011, 07:42:38 pm »
Hi Bill,
I have 2 76/77 barrel's
1 has HR the other KU so not sure that helps
Noel
Offline suzuki27
« Reply #2 on: November 30, 2011, 06:28:51 pm »
Thanks for that Noel. I'm narrowing down the list  of what the mystery engine is in my "CR125". Pretty certain it's not a CR engine from 74-77! Thinking MR, maybe MT.
Offline Noel
« Reply #3 on: November 30, 2011, 09:06:22 pm »
How many gears does it have,
MT MR only have 5 , CR has 6,
what sort or ignition CR CDI ,  MR MT points,
But all of those things are interchangeable as complete units,
MT  will also have provision for oil Pump in casing near counter shaft sproket
74 cases part number superceded  by 76 cases part number
 » www.cmsnl.com » Honda » Search by Model » Motorcycles
If you have a 74 /75 barrel put that on and it will be OK pre 75.
Noel
« Last Edit: November 30, 2011, 10:02:35 pm by Noel »
Offline dkupf
  • Kinka Beach Qld
« Reply #4 on: December 01, 2011, 06:44:41 pm »
Back in the day some people put a 175 cyl on the 125's to make them a 160cc :-X
