Author Topic: '83 Cr480 rear brake plate BrakeRod Bearing  (Read 1989 times)
Offline BultacoMacca
« on: November 26, 2011, 10:48:42 am »
I need to replace my '83 Cr480 rear brake plate BrakeRod Bearing, and as it only had a rough bush in there when I bought it.
I bought a spherical (Heim) bearing from SKF shop but its pretty small - 16mm OD gives 8mm ID but it's too narrow I believe. (The 19mm spherical bearing I bought seems to work & fit OK on the front end.)
What do people use & where to get one?
« Last Edit: December 17, 2011, 11:03:28 pm by BultacoMacca »
