Author Topic: yamaha wr500 92/93 forks compatible  (Read 2097 times)
Taka 100
« on: November 15, 2011, 02:25:43 pm »
I have been chasing a set of yammy usd kyb wr500 zd forks , the left tube is dented and bent (unrepairable), it seems that a few of these yammy models with forks that are interchangeable the list i have is
1991 wr250zb -yz125b-yz250b1
1992 wr250zd-wr500zd-yz125d1-yz250d1
1993 wr250ze-wr500ze-yz250e
i have located a pair of forks in the us that have all the right dimensions as i need except the axle size , he is stating 22mm/17mm
what i need
top clamp 51.8mm
bottom clamp 56.6mm
slider 43mm
overall lenght 3885mm
slider from top of fitting to dust seal 300mm
axle size 20mm /15mm
any help would be appreciated
Re: yamaha wr500 92/93 forks compatible
« Reply #1 on: November 15, 2011, 03:03:58 pm »
I have a lower leg from a 94 YZ125 that should get you out of trouble.
Taka 100
« Reply #2 on: November 15, 2011, 03:30:48 pm »
pm sent
Offline ian
« Reply #3 on: November 16, 2011, 08:21:18 pm »
i think you will find that the 1991 yz125&250 are the same as the wr500 .
