Author Topic: wbt ts185 gearlever and under pipe,xl185 kick lever,early 80s cr80 number plates  (Read 7089 times)
Offline James Lee
Looking for a ts185 gearlever and under pipe for VMX conversion,its a 74,also a xl185 kick lever,early 80s cr80 side number plates,only need the right side but happy to buy a pair.Cheers,James.
I've got a reasonable pair of CR80RC side plates. One of them - can't remember which - has a hole worn in the outer lip.
Yours for the cost of postage.
0400023847
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Here's some good TS185 VMX stuff....
http://www.ebay.com.au/itm/Suzuki-TS185-nos-race-cylinder-and-piston-set-1971-73-/170716072688?pt=Motorcycles_Parts_Accessories&hash=item27bf788af0
http://www.ebay.com.au/itm/SUZUKI-TS185-MOTORCYCLE-RACING-CYLINDER-HEAD-nos-NEW-/130531463746?pt=AU_Motorcycle_Parts_Accessories&hash=item1e64481242
Also a TM250 rotor and stator bolt straight on, just use the TM125 CDI
Ban BLACK rims NOW
Offline James Lee
Thanks for the replies. Nathan Ive sent you a pm about the side plates.Some great links,Im thinking Ill have that head.Does the TM ignition give a perfomance gain?
Offline cyclegod
  • Sunny PERTH W.A
The head is meant for the 175cc race kit cylinders 62mm bore not the 185's 64mm, the ignition will definately boost power and allow the engine to rev more freely.
http://ozvmx.com/community/index.php?topic=5280.0
Ban BLACK rims NOW
Offline James Lee
Awsome thread and bike cyclegod,mine will just be a quick clean up for now I think,do the TM underpipes fit the TS?.Just noticed Im also in need of a suzuki badge for the tank if anyone has one.
Offline cyclegod
  • Sunny PERTH W.A
The TS has a right side port whereas the TM has a left side exhaust port, those kit pipes turn up on eBay quite often I bought my NOS one for $125. I ran a 32mm carb on mine with jetting being the same as 78 PE175 stock settings.
Try asking for a pipe on http://www.vintagemx.us/cgi-bin/swapmeet.cgi  you will probably find one at a cheaper price.
Ban BLACK rims NOW
Offline cyclegod
  • Sunny PERTH W.A
Ban BLACK rims NOW
Offline suzuki447
hi mate have a pipe for 185 .nos underpipe,does your exhaust flange come out on right side when u sitting on bike.i have two ,i think ts125 and 185 both nos.thanks don 0410383202.
bikes in shed.74tm125,76,78,82rm125s,...82,83rm250s.80canam qualifier.80,83yz125s.86yz490.80it125.76it400.80pe175and250.79rm50.76xr75.2xpuch50 magnums.jawa speedway.72honcho 90.84xr200.87xr100.phew thats all.
Offline cyclegod
  • Sunny PERTH W.A
TS185 exhaust port is definately on the RIGHT side
Ban BLACK rims NOW
Offline James Lee
Thats exactly what Im after cyclegod.Don Ill give you a call soon.Cheers,James.
