Author Topic: YZ400E  (Read 18352 times)
Offline oldyzman
  • 250 two stroke!
Re: YZ400E
« Reply #15 on: November 19, 2011, 04:57:13 pm »
Another exhaust option is Les from mainly maico, he sells the profrom. just got one for my 83 CR. Yet to try it but it sure looks fast... Price for the chamber was aroung $300, plus the mufler
Brett
Re: YZ400E
« Reply #16 on: November 19, 2011, 06:16:29 pm »
I recommend the GMC pipe got one on mine , magic .
Offline ARN
Re: YZ400E
« Reply #17 on: November 19, 2011, 08:43:01 pm »
i have a yz400d which has been raced for over 2 years solid other than broken gaurds it hasent missed a beat.
 i also have a gmc pipe and prefer it to the dg as the dg version for the 400 would have to be there worst pipe as it didnt follow the lines of the rear gaurd or tank, the gmc pipe fits neatly.
i did rebuild motor and with a bit of fine tuneing have won many hole shots on this bike even in the evo races ,there a great pre 78 bike ,very traktable motor .
just have to get an edge on them maicos some how
cheers arno 72
Offline mboddy
  • Canberra
Re: YZ400E
« Reply #18 on: November 20, 2011, 07:15:45 am »
would have to change forks as well
What is the difference?
Vinduro Penrite Team
Offline Tahitian_Red
  • Mugen ME480
Re: YZ400E
« Reply #19 on: November 20, 2011, 08:06:05 am »
 more travel, longer tubes and two drain lugs at the bottom of each leg (dead give away).  ;)
The "Factory Novice"
California, USA
Offline James Lee
Re: YZ400E
« Reply #20 on: November 20, 2011, 09:14:32 am »
I think Ill just run in the evo class,I wont be competitive anyway.Can I put 465 forks on my 400,Im sure they are longer and my bike feels very low at the front.I just clicked the link from cyclegod for the gmc pipe and it says he is out of stock,Ill give him a call during the week,hope there not too far away.The DGs are cheaper but Id rather a nice fitting pipe.
Re: YZ400E
« Reply #21 on: November 20, 2011, 09:41:45 am »
Out of stock just means he needs to go do some work, I'm sure that most of his pipes are made to order
Re: YZ400E
« Reply #22 on: November 20, 2011, 12:45:15 pm »
I put a DG on my 78 CR250 and also found the fit not as close as I was hoping for - and Geoffs stuff is good.
Offline ARN
Re: YZ400E
« Reply #23 on: November 20, 2011, 01:23:17 pm »
the standard forks require air about 10 psi ,i have put heavier springs in mine which is heaps better. i have used yz f 1979 forks in my 250d which i ran in pre250 evo for a while they did improve it also, i think the 465 forks would be overkill .
Re: YZ400E
« Reply #24 on: November 20, 2011, 10:53:27 pm »
Yes, pretty much all pipes are out of stock at the moment.
I don't usually get to keep much stock as everything goes out the door as soon as it is finished so I mostly build to order.
I can usually build them within a few weeks from order, but at the moment I have bitten off too much for this year so I won’t be taking any more chamber orders to be finished this year.
When I catch up I will list some as in stock.
And yes you can always ask to have one built.
If you can wait to Jan. sometime I can knock one up if you can wait that long.
number 87
Re: YZ400E
« Reply #25 on: November 24, 2011, 10:03:44 am »
If the only difference between the D and E is an alloy swing arm I can't see why the E can't race with the pre-'78's. An alloy swing arm would make 2/3rds of SFA the difference.
'77 - D = 5 SPEED BOX
'78 - E = 6 SPEED BOX
Plus lots of other little differences
#87
Offline yzhilly
  • Melbourne
Re: YZ400E
« Reply #26 on: November 26, 2011, 08:44:13 pm »
I have fitted YZ250H forks to my YZ400E and it made a huge difference  they are a bit long and i run about 60mm above the top clamp ,My swingarm has been extended by about 50mm where the axle mounts this was done by a previous owner who had it set up for enduro . Good fast bike just put fuel in it and ride
Viper #436
Offline motomaniac
Re: YZ400E
« Reply #27 on: November 26, 2011, 08:57:57 pm »
#87
Thats the 250 not the 400. The 400 has 20mm more overlap on the forks  ,an alloy swingarm thats about 1/2" longer and the frame is Chromemoloy instead of steal so its a bit lighter , plus the hubs are a bit lighter. The motor has only a slightly different piston but if you run a wiseco they,re the same - evrything is interchangable.
Offline James Lee
Re: YZ400E
« Reply #28 on: February 22, 2012, 07:48:04 pm »
I just checked the jets and the main is a 330 and pilot 45,I have an old parts list and it says the main should be 360 and the pilot should be a 60.With todays fuel being different would these numbers still be correct?I would think it would need to be richer.I ran the bike at bmcc on the weekend and the bike was pinging its head off,someone noticed my base gasket was hanging out so I had to pack up for the day,I would think that would have caused the pinging?Ended up being loose cylinder nuts.I really need to get this bike running right.
Re: YZ400E
« Reply #29 on: February 22, 2012, 11:57:12 pm »
The leaking base gasket would've had a lot to do with it pinging. Those jets will be in the ballpark as they always came from the factory too rich but you may need to try a bigger main jet to be safe.
My bikes were a bit lean at Nudgee also but run fine at other tracks
