Author Topic: husky fork seal problems  (Read 6360 times)
Offline Kane Mcguire
« on: November 12, 2011, 04:17:25 pm »
i have always had to run 2 fork seals in all my huskys to stop leaking. i also always cut 10mm out of one of the seal springs. what is the history of this common problem and is there a solution?. the seal stiction is so heavy with 2 seals and also as compared to a modern fork.
Offline huskibul
Re: husky fork seal problems
« Reply #1 on: November 12, 2011, 04:55:58 pm »
    The  husky factory mechanics/riders of yesteryear liked having weeping seals -less stiction , just gotta keep the oil up to em :D
Taka 100
« Reply #2 on: November 12, 2011, 05:18:43 pm »
i was talking to a husky expert who when he was riding enduros in europe , he worked in the factory in sweden and he said to use 30 grade straight mineral oil in gearbox and forks , the same oil as in the briggs and stratton 4t mower engines , might work a treat , you can buy it from bunnings its now marketed by penrite
Offline bazza
« Reply #3 on: November 12, 2011, 05:48:01 pm »
ran 2 x double sealed seals in my 1974 mag motor 250 5 seasons and no fork leak,was using ATF for oil
Embrace patina
Offline euro bikes
« Reply #4 on: November 12, 2011, 05:57:16 pm »
If your fork bush's in the leg are worn it oval shape the seal and they leak.
Offline Mike52
  • 81 KTM 125 LC
« Reply #5 on: November 12, 2011, 06:16:38 pm »
Found an interesting bit of info on another forum.
Apparently Kawasaki KZ1000 fork seals will fit.
One per leg.
Have bought a set to try but they are not here yet.
Will post my thoughts on them later.
Ps . I bought a set of seals off Ebay and they leaked before I even got the bike off the stand. :o
      When I had a close look they didn't have that lip on the outside to seal against the fork slider.
« Last Edit: November 12, 2011, 06:19:54 pm by Mike52 »
Offline Brian Watson
  • First Penton in OZ
« Reply #6 on: November 12, 2011, 06:50:49 pm »
The real problem is that HVA forks aren't 35mm..they are 34.7mm......so get a "green" seal from a Moto Guzzi transmission shaft seal which is 34.7mm and hey presto...no more probs.... No matter what oil you run....:)
Offline grouty
« Reply #7 on: November 13, 2011, 07:02:31 am »
I had leaky fork seals when I bought my 390 about 9 years ago. Replaced them with std off the shelf items from my local bike shop. Two per side. I use an old seal with the spring and lip removed in the bottom of each leg as a spacer. Probably no need, but I do it anyway. It took a few hours of riding to get rid of the stiction. I rebuilt the forks a few months ago, and again had to ride it for a few hours. Never had any leaking problems. I use 15cwt oil and always replace the fork wipers when doing the seals.
There is a Honda seal that fits and was the hot tip back in the late 70's. Maybe someone on here knows which one.
Thumpers Rule !
Offline Mike52
  • 81 KTM 125 LC
« Reply #8 on: November 15, 2011, 07:34:31 am »
One per leg.
40 mm seals with the same part number as the husky ones.
Offline JC
« Reply #9 on: November 15, 2011, 10:00:46 am »
I have a handwritten note that the Honda part # is  91255-273-000 (or 010),
seal size 35x45x7, fits up to MJ06023 but I've never bought a set to see if its correct.
(After MJ06023 seal size is apparently 35x47)
Just measured my old leg (grey slider) & its 34.9mm
KZ1000 fork seals are listed as 36x48 on my Competiton Developments l
"Leakproof" forkseals application list
« Last Edit: November 15, 2011, 10:03:44 am by JC »
Offline Mike52
  • 81 KTM 125 LC
« Reply #10 on: November 17, 2011, 08:35:31 am »
Funny , the seals I got as KZ1000 measure 39/52/10.
Offline Husabergpete
« Reply #11 on: November 21, 2011, 09:25:13 pm »
For my 1983 WR240 - Alan Mallam from Track and Trail in Belmont Newcastle sold me a set of red coloured Marzzochi fork seals about 20 years ago - he promised they would work and they did. Never a problem since that date. Problem now is getting them again.
Pete
