Author Topic: Cz rear spokes and axle  (Read 3848 times)
« on: November 04, 2011, 12:06:34 pm »
Where's a good(cheap if possible) source for spokes? I've got a wheel to build using an early 70's rear hub.
Also, would anyone have a spare rear axle for sale?
Re: Cz rear spokes and axle
« Reply #1 on: November 04, 2011, 04:18:45 pm »
From memory when I talked to Les earlier this year he had spokes in stock but not loaded onto the website
« Reply #2 on: November 04, 2011, 04:54:13 pm »
Keep in mind that the 74 & later axles are longer than the earlier models
Offline foxy999
« Reply #3 on: November 04, 2011, 06:17:36 pm »
Ash's Spoked Wheels Brisbane
35 Crosby Road Albion Brisbane 4010 Ph: 07 3262 6447 Fax: 07 3262 4890 Email,  he done a great job on my 360 rear wheel. he even made a few spares for me.
My fastest lap is the first one :)
« Reply #4 on: November 04, 2011, 08:09:35 pm »
Thanks guys, I've used Ash's before and can agree the service and product is pretty good. Handy to know they've made sets up before.
Cheers Geoff, the swingarm the wheel is going into is 205mm externally, do you know which axle I'd be after in this case?
« Reply #5 on: November 04, 2011, 08:33:42 pm »
The 74 axle would suit a swingarm around 270 outside width.
The 73 and earlier CZ's had the swingarm tubes flattened which is why the axles are shorter, don't have the measurement for them on hand.
« Reply #6 on: November 04, 2011, 08:37:04 pm »
Pretty sure all pre74 axles would be very close to the same length, will be removing my rear wheel tomorrow & can measure it for you
Offline foxy999
« Reply #7 on: November 04, 2011, 09:23:19 pm »
so what is this going on?
« Reply #8 on: November 04, 2011, 10:26:06 pm »
This will be going on the 350 BSA I'm building, if everything works out it'll be ready for the Nats
That'd be great, thanks
« Reply #9 on: November 08, 2011, 07:20:18 pm »
Finally got the wheel out to lube the brake cam, sizes follow
Shaft diameter 17mm
Overall length from under head 225mm
Thread length 25mm
Thread diameter 16mm x 1.5mm pitch
« Last Edit: November 10, 2011, 05:10:20 am by tony27 »
« Reply #10 on: November 09, 2011, 10:17:59 pm »
Shaft diameter 17mm
Thread length 25mm
Thread diameter 16mm, will take to work & measure pitch tomorrow
Looks like that's the one I'm after, thanks for taking the time to measure that up
« Reply #11 on: November 10, 2011, 05:12:54 am »
My pleasure, had lots of help from other members so least I could do
